View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2361
    Jan 2012
    I have issues with RR. I can randomely play music, but as soon as i go in the music browser,where my music is listed, itīs not playable. I get an error message instead saying:"We interceptet a COM Error! err description: Database file is open.
    errnumer 80020009
    err source LiteX.LiteConnection.1
    any fix for this? please
  2. #2362
    May 2008
    San Jose, CA USA
    This is not the place for classified ads - Enforcer
  3. #2363
    Newbie whteglve's Avatar
    May 2006
    Clemmons, NC
    Win7, 8GB, i7. 9-1-12 Riderunner. Plugins - RRTMS, DFXVoice, RRFuelPrices, WifiMan. Skin - Reborn.
  4. #2364
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Did not update or change a thing. Stable install running for months all of the sudden DFX starts and all buttons and info is blank. Tried updating flash, graphics driver, RR 11-1-12 etc...nothing working. Carwings works fine. Any thoughts?
  5. #2365
  6. #2366
    Nov 2007
    PA
    Updated Flash, Video Drivers, Bios, latest RR you name it DFX has no display on buttons. Music displays up top that's it. Any further ideas??
  7. #2367
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Dougw133 View Post
    It sounds like your skin.ini may be corrupted. Back up your existing skin.ini. Then go to !SkinBackupIni and drop a couple of the skin,ini.bak files (after removing .bak) into your DFX folder, starting with the newest. Hopefully, that will work. If not, do a reinstall of DFX, making sure during the installation process to tell it to overwrite all settings.
  8. #2368
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    I just had almost the same exact scenario happen over the weekend. Was working for months without issue then I went to play a video and the resolution was huge and I couldn't get it to change so I rebooted now I get blue screen because the Lilliput can't handle the resolution (but RR is running in the background fine). When I hook up a regular high res monitor to debug, everything looks good. Made sure XP resolution and refresh rates are set ok, etc. Still trying to figure out what the heck to do next. It's not easy debugging in the car not just because of hooking up hardware (monitor, keyboard, etc.) but you have to keep the car running or else the opus power supply will gracefully shutdown.
    "Imagination is more important than knowledge." -AE
  9. #2369
    Oct 2012
    I've got a strange problem with RideRunner and latest DFX 5.1 (November 1 build).
    When viewing the Radar Map, National Weather Map, or (national) Temp Map under Weather, approximately every 2 minutes the software speaks what sounds like random gibberish, but it's repeating the same thing over and over. It is speaking individual letters and sounds like part of the speech is the station identification for one our local TV stations. I'm wondering if the software is perhaps retrieving the radar data from that station. I know it says "Weather Channel."
    This does not occur when viewing Current Weather or 4 Day Forecast. I reside in the USA. Asking the system to speak the current forecast functions normally.
    Either way, it's quite annoying. The speech is so rapid that I can't make out all of the characters. The string seems to be around 16-20 characters or so. I don't see any such text on the screen, so it is something hidden. Perhaps part of some data stream???
    Anyone have an idea of what this could be, why RR would be reading these characters, and how to stop it?
  10. #2370
    Nov 2007
    PA
    Quote Originally Posted by kbreeden View Post
    Thanks I'll give that a shot. Also, thank you Enforcer didn't see that post.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
