View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 238 of 242 FirstFirst ... 138188228229230231232233234235236237238239240241242 LastLast
Results 2,371 to 2,380 of 2412
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2371
    Oct 2006
    Quote Originally Posted by kbreeden View Post
    It sounds like your skin.ini may be corrupted. Back up your existing skin.ini. Then go to !SkinBackupIni and drop a couple of the skin,ini.bak files (after removing .bak) into your DFX folder, starting with the newest. Hopefully, that will work. If not, do a reinstall of DFX, making sure during the installation process to tell it to overwrite all settings.
    This is a RR Bug, Fixed in 12/1/2012 as per RR 12-01-2012 Release
  2. #2372
    Oct 2012
    More Info on Strange Speech in Weather
    I have an update to this problem. I re-installed a fresh version of RR 11.01.2012 build, then a fresh copy of DFX 5.1.2, then installed all updates to DFX (via default Menu 4 button). Everything was fine with the Weather screen until I tapped the 'Reload Weather' button. It spews out the same gobbledy-good speech. I have noticed the speech repeated is the same. It is spoken so quickly that I can't quite make out what it is saying, but it appears to be spelling out something (presumably the text does not match any word, so it is spelling it out).
    I've also noticed when I close RR that it speaks "kill winamp"
    Is there a way to disable RR speaking hidden text? Perhaps that would solve the problem.
    RN
    Quote Originally Posted by RadarNutt View Post
    I've got a strange problem with RideRunner and latest DFX 5.1 (November 1 build).
    When viewing the Radar Map, National Weather Map, or (national) Temp Map under Weather, approximately every 2 minutes the software speaks what sounds like random gibberish, but it's repeating the same thing over and over. It is speaking individual letters and sounds like part of the speech is the station identification for one our local TV stations. I'm wondering if the software is perhaps retrieving the radar data from that station. I know it says "Weather Channel."
    This does not occur when viewing Current Weather or 4 Day Forecast. I reside in the USA. Asking the system to speak the current forecast functions normally.
    Either way, it's quite annoying. The speech is so rapid that I can't make out all of the characters. The string seems to be around 16-20 characters or so. I don't see any such text on the screen, so it is something hidden. Perhaps part of some data stream???
    Anyone have an idea of what this could be, why RR would be reading these characters, and how to stop it?
  3. #2373
    MySQL Error
    Oct 2004
    Quote Originally Posted by mrbombastic View Post
    this is NOT a bug in RR
    its a bug in RR config.... oddly no one noticed the corruption of skin.ini, its not hard to notice it, when you look at it and see that its the contents of general.ini
    and thanks to dartman_71, i wouldnt have noticed it too... since the skin i use, doesnt really use skin.ini for much
    but this is a new bug(only prob 1 month old)... so for safety, since dfx stores lots of settings in the skin.ini, keep a backup!
    and its fixed in V1.0.0.15
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #2374
    Constant Bitrate overlander's Avatar
    Feb 2008
    Quote Originally Posted by PhilG View Post
    This:
    http://store.mp3car.com/MJS_SC_C1_US..._p/sat-011.htm
    gets connected via USB to the PC and this:
    http://www.bestbuy.com/site/SIRIUS+-...c-c1&cp=1&lp=1
    via an included cable with the first device.
    The audio from the first device connects to the line-in on your sound card.
    You connect the vehicle 12v power to the first device, it powers the second device from there.
    Plug in the antenna included with the second device and point to the sky and your golden.
    I've had this setup for several years now and it works excellent.
    So I just got both of those devices-the SCC1 and mitch's interface. Hooked it all together and to the PC (xp machine), installed Mitch's drivers (no errors) gave it a dedicated com port (10), set the com port in RRconfig, gave the interface 12v power, and all seems fine. Then I run Sirius Demo from Mich's driver package, and it can't find the interface. I run RR w/ DFX (latest updates) and when I press the sirius button I get the nogo screen that says "sirius radio not registered".
    This was supposed to be plug and play so any theories? I haven't subscribed yet as I wanted to make sure everything is working right before doing so, and I was going to hit up the demo channel 184 to confirm all that.
    Anybody?
  5. #2375
    Feb 2008
    I hate when I post a question like this then resolve it right after! Ok, it ended up being a 12v supply issue to the interface. all worked out now and everything works.
  6. #2376
    Oct 2006
    Quote Originally Posted by DaveDog View Post
    Sorry, updated the post.
    without even trying to use DFX Voice, RR locks up when DFX loads up, sometimes you have to press a button.
    Carwings didn't lock up, deleting DFX5 completely from the system and re-installing didn't fix it, removing DFX Voice fixed it.
    Let me know if I can assist any further.
    How do you disable DFX Voice ?.
  7. #2377
    lep
    lep is offline
    Jul 2011
    video problems
    video works 100% with car stopped!
    but video is locked with moving car ... how to work? thanks
  8. #2378
    Jun 2002
    Virginia
    Quote Originally Posted by lep View Post
    Go to the DFX plugin manager and disable the motion lock plugin.
  9. #2379
    lep
    lep is offline
    Jul 2011
    THANKSSSSS
    VAI CORINTHIANSSS
  10. #2380
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    I managed to use RRWebRadio in DFX.
    Here's the needed files if anyone wants to use it in dfx.
    Not perfect by any means, but it works.
    Enjoy.
    Attached Files Attached Files
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
