View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 239 of 242 FirstFirst ... 139189229230231232233234235236237238239240241242 LastLast
Results 2,381 to 2,390 of 2412
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2381
    Dec 2008
    Start up problems
    Hello, I'am having problems with RR on start up. I just installed the newest version of both RR and DFX. When RR starts up, it plays a song during the DFX splash screen. But once the skin loads the "title" and " artist" name is blank. When I press "music" the song info appears but it stops playing, sometimes it even changes to a different song in the playlist. Any ideas on how I can fix this? thanks
  2. #2382
    Oct 2012
    @Dgr8wun: What is your music source (e.g. NetRadio, local Music on CarPC, Shoutcast, etc.)? What OS are you using?
  3. #2383
    Dec 2008
    Quote Originally Posted by RadarNutt View Post
    Local music, winamp and windows xp. I noticed the music starts playing once dfx loads the player.
  4. #2384
    Oct 2012
    Quote Originally Posted by Dgr8wun View Post
    Did you verify your setting in RRConfig? It is under Music > Modes
    There's some discussion on one of the RR threads about a similar problem and verifying one of the settings. I recall something about setting a variable =2, but I can't find the thread atm. I'll try and dig it up.
    Also, do you have latest or recent WinAmp version?
  5. #2385
    Dec 2008
    Yes the latest. I also tried playing with the "resume" set up in rr but it still did it. Also do you know how to disable dfspeak? I dont have a mic and it gives me an error that prevent the pc from shutting down without manualy "ending" the program. Thanks
  6. #2386
    Nov 2008
    Maybe this has been mentioned, but with so many pages I couldn't find an answer. After updating to the newest version of RR and DFX the weather no longer works. When it loads everything is blank. Any fix to this?
  7. #2387
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    http://www.mp3car.com/rr-released-sk...er#post1468303
    I've Been gone for awhile and the forum seems really slow, what happened? Anyway i was going thru the forum to reacquaint myself and i ran into that post. Not really sure if thats your answer though.
    If you cant DODGE em, RAM em.
  8. #2388
    Nov 2008
    Quote Originally Posted by Ramanator View Post
    Hmm. Yeah, that's probably it. I'll have to check out the other plugin. Thanks.
  9. #2389
    Oct 2012
    Search around in the RR forum. I'm sure that has been addressed before for others.
    Goto Plugin Settings > DFXvoice and press Disable
    That should not be an issue (not having a mic). I used mine for some time without a mic and I regularly un-plug the mic to update/install software, and no issues.
    Overall, it sounds to me like you have some kind of config issue with either RR or the OS (given the probs you seem to be having). Are you using a N-Lite'd build of Windows XP? Which SP are you using?
  10. #2390
    Feb 2007
    Motor City
    Just out of curiosity, is this skin still supported? I remember John, Blue, Guino, and a host of other DFX'ers all over these here threads. Hopefully the holiday season is keeping folks out of the forum but i doubt it seeing that the dates on the posts are obvious indicators. Anyway, I broke my xp disc and it seems i will be stuck with windows 8, is there any advantage to 8 or am i screwed?
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
