View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 241 of 246 FirstFirst ... 141191231232233234235236237238239240241242243244245246 LastLast
Results 2,401 to 2,410 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2401
    Apr 2012
    thanks for the reply
    Usually thats the first thing i tried...no idea why i didnt this time! lol
    So after a full re-install using a default setings rr.ini file rr with dfx will get pasted that screen but rr doesnt work - i can see the basic layout but parts are see through and showing the desktop
    If i replace my back-up of my old rr.ini file it gets stuck at the loading screen again....
    I prob should have mentioned im running windows 7 64 bit
    also should add i have no issues loading RR with either rr.ini files in carwings
  2. #2402
    Raw Wave
    Jun 2002
    Virginia
    Try it with the Carwings skin that comes with RR. That will at least show whether it's a skin issue or a RR issue. Then we can go from there.
  3. #2403
    Apr 2012
    Somehow, although I'm not sure how, the skins now working fine lol. Thanks for your help :-)
  4. #2404
    Apr 2012
    Sigh, OK so Im having issues with the launch menu only in dfx.
    Its not launching calculator or notepad or my own app however these work in car wings and other skins.
    Basically when I select an app and select run nothing happens.
    Any ideas?
  5. #2405
    May 2012
    Wisconsin USA
    I am having a freezing issue on a fresh install. Everything works in carwings though. It freezes randomly after the loading screen never loading the main menu. I have tried fresh installs right down to Windows 7. I tracked it down to when I enable the startup volume. If I leave it disabled all is well but when I set it at anything the skin hangs. Brand new motherboard (d2700mud) with correct audio drivers...not the Windows ones. Any ideas?
    I blame any errors on auto correct...since I an sending this from my Galaxy S3
  6. #2406
    Aug 2006
    Angry
    Did a quick search of this thread and didn't see anyone else having an issue; I posted this same issue in the general RR section, but was referred here, so I'll reiterate what I originally posted.
    I have the DFX plugin (v5.1.2R build 2\1\2013) and it's a fresh install of both the skin + RR.
    No matter how much I clean out and make sure it's a fresh install (when doing stuff like updating RR because of a new version and getting nagged that it's out of date) I still get this problem.
    Here's the error message (and I will include a screen shot of it):
    "RideRunner screen loading error!
    While loading: menu1.skin
    menu1.skin not found."
    This happens when I tap on "Menu" to go between the 4 different menus within DFX.
    Any ideas?
    http://img802.imageshack.us/img802/8747/errorqz.png
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
  7. #2407
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    In your dfx5 folder you should have menu.skin & several menux.skin's where x is 2 - 6.
    And in your menu.skin file, depending on which skin build you got, you should have one of two lines:
    [OLDER]
    B10,0,526,101,73,"LOAD;menu2.skin",""
    [NEWER]
    B10,0,526,101,73,"DFX_MainMenuNext",@SetMenuScreen Limit@
    So i'm not sure where exactly its getting menu1.skin from
    Also try setting one of the menu btns to Skin Update and get the skin up to date if you haven't done so... It may just fix this issue as well as bring the skin current.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  8. #2408
    Aug 2006
    [OLDER]
    [NEWER]
    1) I don't have a menu.skin file, just the subsequent files, menuX.skin (where X is 2-6)
    2) this is a FRESH install of both RR and DFX, it's the 3\1\2013 DFX install and the March RR install
    3) I already tried using the "Skin Update" feature within the skin, clicking the buttons don't do anything. Also, I couldn't assign one of the buttons to the "Skin Update" function, that's another issue it's having; normally you can long press on one of them and change its functionality to something else, but when I long press, nothing happens. I had to use the one already on page 4 by default (the "Skin Update" button)
    4) It's NOT installed in "profile" mode
    Where can I get the menu.skin file? Because the installer is not installing it properly
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  9. #2409
    Mar 2013
    Where can you get Sygic for PC?
    Quote Originally Posted by CherokeeChief View Post
    Thanks for adding Sygic ! ;-)
    Hello,
    I went to the Sygic web page and I can't find a PC Windows version. Where can you get it?
  10. #2410
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
