View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 242 of 246 FirstFirst ... 142192232233234235236237238239240241242243244245246 LastLast
Results 2,411 to 2,420 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2411
    Mar 2009
Size:  78.5 KBName:  phone.jpg
    .net Bluetooth Mobilephone Plugin error
    phonecontrol.net feature
    feature not installedd
    you are trying to use the phonecontrol.net feature which has not been installed
    please rerun the riderunner installer and select the phonecontrol.net option to use this feature
  2. #2412
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    My lilliput crapped out on me at 800x600 resolution last year and I just couldn't do anything to get it to work. The other day, I gave it one last shot and ran the output from my carpc to an external monitor as I've done many times before but this time, I decided to try the 'build in' update. I did the update, selected 1024x768 and let it update. I then changed my screen resolution to the same and viola, my lilliput is functioning again! I still get the 'I'm dead blue screen' while booting but then it comes to life when hitting 1024x768 resolution. I was just getting ready to pull the plug and order another touch screen monitor! I've been using it for 3 weeks straight and it works perfect again.
    DFX is a great skin! Thanks
    "Imagination is more important than knowledge." -AE
  3. #2413
    Low Bitrate jparks27's Avatar
    Feb 2006
    Maryland
    *** Fixed - leaving here in case someone has similar issue ***
    Apparently my computer (Dell Studio Hybrid, 140G), has a RealTek soundcard. The card doesn't recognize a valid output unless something is connected. IOTW, because I didn't have a cable plugged into the audio output jack, it registered as NOT having anywhere to send sound to.. Which in turn caused DFX5 to crash (for some reason), but not carwings.
    Weird, how a simple 3.5mm cable can cause software to stop responding.
    __________________________________________________ __________________________
    Fresh win7 install, got riderunner installed, loads with carwings, but crashes with dfx5.
    Just hangs, after it says 'loading DFX5' on the splash screen.
    05/29:
    00:17:47.815: Start -- Version: 5/1/2013
    00:17:47.815: OS Type: Windows 7
    00:17:47.815: FileManager: FileMode = Legacy
    00:17:47.815: FileManager: mypath = C:\Program Files\RideRunner\
    00:17:47.816: FileManager: ProfilePath = C:\Users\User\Documents\RideRunner\
    00:17:47.865: Start Sequence: Starting Player...
    00:17:47.866: PLAYER: Initialization creating object
    00:17:47.868: PLAYER: Started
    00:17:47.870: PLAYER: Winamp Version: 5.63
    00:17:47.870: PLAYER: Initialization complete
    00:17:47.871: Start Sequence: Starting Radio Device...
    00:17:47.872: Start Sequence: Starting Serial Devices...
    00:17:47.873: Start Sequence: Starting Mixer...
    00:17:47.922: VMC---> Set object successful
    00:17:47.923: VMC---> SourceLine Count: 0
    00:17:47.933: Start Sequence: Starting Speech...
    00:17:48.277: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    00:17:48.278: INFO: LoadSkinVars() - Reading data from C:\Program Files\RideRunner\Skins\DFX5\skin.ini
    00:17:48.292: Plugin Manager: loading Global Plugins...
    00:17:48.295: Plugin Manager: Plugin Found: InetRadioLabels
    00:17:48.295: Plugin Manager: Plugin loaded (Global): InetRadioLabels
    00:17:48.300: Plugin Manager: Plugin Found: RRExtended
    00:17:48.301: Plugin Manager: Plugin loaded (Global): RRExtended
    00:17:49.842: Plugin Manager: Plugin Found: RRMediaDB
    00:17:49.842: Plugin Manager: Plugin loaded (Global): RRMediaDB
    00:17:49.852: Plugin Manager: Plugin Found: SkinTool
    00:17:49.852: Plugin Manager: Plugin loaded (Global): SkinTool
    00:17:49.855: Plugin Manager: Plugin Found: Weather
    00:17:49.855: Plugin Manager: Plugin loaded (Global): Weather
    00:17:49.861: Plugin Manager: loading Global Plugins Completed.
    00:17:49.861: LoadSkin: C:\Program Files\RideRunner\Skins\DFX5\
    00:17:49.903: INFO: LoadSkinVars() - Reading data from C:\Program Files\RideRunner\Skins\DFX5\skin.ini
    00:17:49.913: Plugin Manager: loading SkinDir Plugins...
    00:17:49.916: Plugin Manager: Plugin Found: DFX5
    00:17:49.916: Plugin Manager: Plugin loaded (SkinDir): DFX5
    00:17:49.960: Plugin Manager: loading SkinDir Plugins Completed.
    and DFX debug
    5/29/2013 12:29:11 AM: Initz: DLL Path: C:\Program Files\RideRunner\Skins\DFX5\Plugins\DFX
    5/29/2013 12:29:11 AM: CustomMixerSetup: Setting up the custom mixer array
    5/29/2013 12:29:11 AM: LblSetup: Setting the screen Image cmds and Index's
    5/29/2013 12:29:11 AM: SetThemeIndicators: Setting up the theme day night color indicators
    5/29/2013 12:29:11 AM: MediaDriveCheck: Checking the media drive for media type
    5/29/2013 12:29:11 AM: MediaDriveCheck: Checking if media is a audio CD
    5/29/2013 12:29:11 AM: MediaDriveCheck: Checking if media is a video DVD
  4. #2414
    Constant Bitrate Morpheus2010's Avatar
    Jul 2007
    orlando
    does anyone know if dfx and all its features works on win 8? i remember there was issues with win 7 64bit especially when trying to use voice.
  5. #2415
    Nov 2008
    Quote Originally Posted by Morpheus2010 View Post
    I was wondering the same thing.
    ALSO, any chance of getting this to run on Android devices? John, I know you said this, "Sorry, but there is just no way to get RR to run on anything other than windows. It is written in VB6, and heavily depends on the windows OS to function." However, that was back in 2009, nearly 4 years ago, and I was wondering if there has been any changes to this. Considering there are so many android tablets these days, and even car stereo touchscreens running android, that RR on android seems a must...
  6. #2416
    Raw Wave
    Jun 2002
    Virginia
    I think it's safe to conclude that development of DFX is at an end and that it's extremely unlikely that it will ever be modified to work with Win8 or Android. John and Blue have moved on.
  7. #2417
    Nov 2008
    Quote Originally Posted by kbreeden View Post
  8. #2418
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Hmmm, I'm starting to believe that same notion that DFX may have died a silent death,......please say it isn't so.
  9. #2419
    Raw Wave
    Jun 2002
    Virginia
    I believe so. I think both John and Blue burned out on it. Plus there are so many alternatives to a carputer available now that interest subsided. I saw that on Blue's DFXVoice thread. He was working his butt off to make a great voice control system for RR, which I use regularly, and there were only two people paying any attention. The good news is that DFX is quite feature-rich and stable already so as long as one does not have to use the latest and greatest operating system, it works great.
  10. #2420
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    DFX needs RR to run.
    RR is a VB6 based FE and as such can not run on Android.
    To port to android would need a complete rewrite which Mitchjs has ruled out, ell it won't even be converted to .net.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
