View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 244 of 246 FirstFirst ... 144194234235236237238239240241242243244245246 LastLast
Results 2,431 to 2,440 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #2431
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by goldenley View Post
    Putting together a system for the first time since 2007. Fresh XP SP3 install, fresh RR install, and decided to give DFX a try as my skin (since it seems to be the only one with active support). I went to set up my music first and followed the instructions to click "Build Music Database" to get started, but all I get is an error message "Automation Error, Invalid Syntax, RMBuilder". I did a thread search and didn't see anything useful. I have the latest version of everything. Any helpful hints on how to get the music for this skin set up?
    Do you have the RRMedia plugin installed ?
  2. #2432
    Jun 2007
    Colorado
    Quote Originally Posted by pierrotm777 View Post
    weird, I think I've forgotten more than I ever knew about plugins. Under RRConfig, the only plugin that shows up is Weather, but under the \Program Files\RideRunner\Plugins\ folder, I see GPSLockout, InetRadioLabels, RRExtended, RRMedia, SkinTool, and Weather.
    So I guess RideRunner didn't install all those other plugins? How do I do that?
  3. #2433
    Jun 2007
    Colorado
    well, RRMediaDb shows up in the Plugin Mgr in Menu4, does that mean it installed correctly?
  4. #2434
    May 2008
    Bordeaux, France
    Go to the Plugin Manager screen !
    If you see RRMedia, it's installed !
  5. #2435
  6. #2436
    Dec 2010
    Twilight Zone
    Ok, hopefully someone here can assist me. I have been tooling around with RR and DFX 5.1.2 for the last month or so, on and off, trying to fine tune it before I install my system I am slowly getting there.
    The major hurdles I have worked on, was getting Navigator 12 to play nice, and now, my new test of will.
    I found that it was first introduced in DFX 2.0, a plugin for a police/fire scanner, which works with ARC15, an outside program that virtually controls the Scanner (here is link to the referenced program http://www.butel.nl/products/bct15/bct15.html ). It worked with several scanners, including the Uniden BCT15. Since then, they released a newer model, the BCT15X, and subsequently new software to control it (link to the referenced program http://www.butel.nl/products/arcxt/arc_xt.html ).
    As for the DFX 5.1.2 .ini I have found a couple areas where this is referenced. I changed the button #2 in DFX to 'Scanner', and it comes up with the DFX menu/controls. I had to then edit the .ini to find the correct path to the program at hand, and it did launch the program externally, but did not seem to tie in with DFX controls.
    So here are the snippets of the DFX .ini I have found so far.
    [Main Menu Button Options]
    MenuExec_28=Load;Scanner.skin;RC15PRO software for Uniden BCT-15;C:\Program Files\BuTel\ARC15PRO\ARC15P.exe;RC15PRO software for Uniden BCT-15
    MenuLabl_28=Scanner
    MainMenuExec_02=Load;Scanner.skin;RC15PRO software for Uniden BCT-15;C:\Program Files\BuTel\ARC15PRO\ARC15P.exe;RC15PRO software for Uniden BCT-15
    MainMenuLabl_02=Scanner
    [Descriptions]
    DescScanner=Software interface for some hardware scanner software, to control through the CarPC.
    The default pathway in the .ini is not where my program ended up getting installed, so I am assuming I have to change the DFX .ini with the correct location?
    In the "ExecTBL.ini" I found this additional information to embed an external application.
    /------------------------Embed External Applications------------------------------------
    "Scanner","Load;Scanner.skin;RC15PRO software for Uniden BCT-15;C:\Program Files\BuTel\ARC15PRO\ARC15P.exe;RC15PRO software for Uniden BCT-15"
    "ScannerControl","SENDKEY;"{F12}||Load;Scanner2.sk in;ARC15PRO - Virtual Control PRO;$RRPath$WeatherDownloader.exe;ARC15PRO - Virtual Control PRO"
    The second part "ScannerControl" is not in the existing DFX .ini , assuming it needs to be added, but not sure where.
    Also, the other issue is that the programs that are able to be embedded in DFX you need to purchase. There is another similar program that is free, and also allows for Virtual Control of the scanner in a similar fashion, would there be any chance of this program working with DFX, or someone crafty enough to get it to? ( https://sites.google.com/site/sixspo...ducts/freescan ).
    Hopefully someone can give me a little more insight!!! Thanks!!
    As of 4-10-14
    CarPC Progress: 60%+ Starting from scratch with old laptop. Trying to figure out how to get all the programs I want/need for RideRunner!
    My Build/Install Thread
  7. #2437
    Dec 2010
    Twilight Zone
    Anyone?? Bueller??
    As of 4-10-14
  8. #2438
    Apr 2003
    Germany
    I have RR working on XP.. Installed DFX 5.1.2. Every thing works but, I have after starting DFX two errors..
    1e)- DFX speak error, err #91, Source: DFXSpeak, object variable or with block variable not set.
    2e) DFX speak Error, err #429, Source: DFXspeak. ActiveX component can't create object.
    I installed SAPI SDK but no luck... RR and DFX reinstalled... no luck... Search internet.. no luck...
    So.. whats wrong?
    Thx Bob
    Chrysler Voyager, atom. riderunner, dfx
  9. #2439
  10. #2440
    Dec 2010
    Twilight Zone
    REALLY hoping someone can check out my question in Post #2436 - http://www.mp3car.com/rr-released-sk...ml#post1502287
    I am close to getting my PC installed, and really want to finish programming before it is installed. I suppose I could live without this function, but it would REALLY make life a lot better for me!!
    As of 4-10-14
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
