View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 25 of 246 FirstFirst ... 15161718192021222324252627282930313233343575125 ... LastLast
Results 241 to 250 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #241
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    Quote Originally Posted by JohnWPB View Post
    Ok, to adress this again, as it was brought up in the DFX3, 4, and now 5 thread
    The menu button I have found most used of all the buttons, and is on the far left, as 90% of users of this skin are in left hand drive vehicles. This is based on the DFX4 downloads by geographic area. The Play, RW, FF buttons are dead centered, no matter which side you drive from. The volume buttons are on the right, as I have found that most people use a volume knob, or head unit to control the volume, as I do as well.
    On a last note, on a standard 7" screen, I am sorry, but you will have to reach all to way over, contorting and stretching, to the other side of the screen to control the volume As it is around a whopping 1 to 2 inches further to reach In some situations I guess a passenger could be asked nicely to press the volume down button from their side of the car. I have to wonder if some people, when using a head unit, if only presets for the radio 1 through 3 are the only ones used, as 4 through 6 is just too far to stretch.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  2. #242
    Jul 2010
    Hi, propably this is a dumb question but how to use telephone? I have iphone4 and latest bluesoleil. Maybe someone cal give me a ling, because im sure is somewhere there, i just cant find it.
    Thanks in advance.
  3. #243
    Sep 2008
    Quote Originally Posted by zenonek View Post
    Thanks in advance.
    I asked this same question twice and didn't get any responses.
    Since then, for some reason, it just started working. I can't explain why.
    I have the iPhone 3G, 4.1 firmware. All I can tell you is, follow all of Lambospirit's directions over on the mobilephone.net thread EXACTLY. If you can get the phone to sync with Bluesoleil, you should be good. Just get in DFX5 and see if the telephone icon is lit up on the main menu.
    Good luck.
  4. #244
    Sep 2008
    I'm not sure if this is a bug or supposed to be that way but has anyone noticed the rewind button replacing the Play/Pause button in the Garmin screen?
    Just curious
    Thanks!
  5. #245
    Apr 2010
    Quote Originally Posted by JQFletcher View Post
    Just curious
    Thanks!
    Yup, same here. I don't think its supposed to be there but it still works to play/pause so I haven't messed with it yet.
  6. #246
    Jul 2010
    Good luck.
    thanks, but i have problem when installing plugin, first of all it saing that i have no vc++ installed, but i have, then is saing dll not registered. Im stuck for now.
    But i will give it a go once more.
  7. #247
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by gasse View Post
    I choose to use Fennec as my default browser on dfx, but it doesn't start. When I press "Browser", browser skin starts but no Fennec on it. Am I the only guy with this problem? Editing skin.ini using "FENNEC" instead the long string "BYVAR..." is a working solution, but this "solution" is not as nice as "BYVAR..." solution.
    You must to set the good path for FENNEC into the rr.ini file :
    browserpath=c:\Program Files\Internet Explorer\iexplore.exe for explorer .
    browserpath=c:\Program Files\Fennec\fennec.exe for fennec by exemple
  8. #248
    May 2008
    San Jose, CA USA
    Not sure if anyone else is having this issue, but it seems like DFX5 uses way more CPU. Mine just sits on 97%. Do you think it's because of the RRvoice sitting it the background?
  9. #249
    Oct 2008
    Midlands, UK
    Tpms
    @ John - thanks for the reply, hopefully there is someone using DXF5 and Robby's hardware that can steer me in the right direction.
    I have been reading up on how to do my own skin, because my personal preference would be to have the car in the picture orientated the same way as the actual vehicle. It's looks easy enough to make the skin, but I don't know how to pull in the sensor data. Perhaps I should try posting in Robby's TPMS thread.
    Thanks for a great skin, I'm looking forward to upgrading from 4 to 5 :-)
  10. #250
    Sep 2008
    Quote Originally Posted by cameronlazzari View Post
    I would look elsewhere for the culprit. I use an Intel Atom and it hovers around 3% to 4%.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
