View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 28 of 242 FirstFirst ... 18192021222324252627282930313233343536373878128 ... LastLast
Results 271 to 280 of 2414
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #271
    Oct 2008
    Midlands, UK
    Tpms
    Thanks Enforcer:
    I took your advice and moved rrtms.dll to the plugins folder and re-registered. I restarted RiderRunner and hey presto, sensor data in the TPMS screen.
    @John - I can now confirm your new tms.skin does work correctly. Well, it does under normal conditions, but I expect it will also be fine also displaying temp and pressure errors. Thanks.
  2. #272
    Oct 2008
    Midlands, UK
    Quote Originally Posted by turbotimbo View Post
    Thanks Enforcer:
    I spoke to soon, or more precisely, I didn't look properly - it is almost working. I've got the temperature and pressure readings from all 4 sensors, but no battery indicators. All the icons look good in the slider_battery folder.
  3. #273
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Try this.
    Have a look at the TMS.skin
    look for the following line
    PHP Code:
    Y01
    ,"slider_battery\SLIDER_*.gif"
    and move it up above the sliders like so
    PHP Code:
    Y01
    S01,174,460,90,34,559,77,47,34,H,01,"",0,"TMS_BATTERY_RR",""
    S02,683,460,90,34,156,77,47,34,H,01,"",0,"TMS_BATTERY_FR",""
    S03,174,88,90,34,559,532,47,34,H,01,"",0,"TMS_BATTERY_RL",""
    S04,683,88,90,34,156,532,47,34,H,01,"",0,"TMS_BATTERY_FL",""
  4. #274
    Oct 2008
    Midlands, UK
    Thanks again Enforcer, that fixed it
    I did suspect that line because it was different to Robby's skin
    @ John - That looks like a bug fix for the next release/patch.
  5. #275
    Sep 2008
    Has anyone seen any odd behavior on the HD Radio skin in regards to presets?
    I use the Visteon HD Radio module in conjunction with the HD Radio screen in DFX5 and I set a few presets the other day. Then I got in the car and the presets were gone. So, I set a few new and different ones. Then, I got in the car a couple days later, and the old presets were back and I was missing the newer ones I set.
    Any ideas?
  6. #276
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    JQFletcher
    Click on the LOCAL button, and you will see how it works...
    One list is for roaming, to other cities...
    ...JJG
    RRVoice Version 1.1.0.10 BETA
    RRVCConfig Version 1.0.0.69 BETA
    RRMouseTrap Version 1.5 Beta
    RRPointer Version 1.0 BETA Update Soon
    RRTTS Testing
    RRScript Testing
    SerialSwitch In Development
  7. #277
    Mar 2007
    Nashua, NH
    Is there a way to force a Wifi connection? I saw the topic in the help entitled, "How do I Connect to the Internet through the skin?" but that is for dial-up. Nothing for wifi. I know there was a plug-in to manage the WLAN connection. Is that completely gone? ...for now???
  8. #278
    May 2005
    Monterey, CA
    In case anyone is interested / using dual displays I have modified the skin to work with dual display. So the 2nd monitor is used to display the GPS at all times and then when you select GPS you can control it and send it back to the the 2nd display.
    I have most of the work done just need to get some more code working to control the GPS properly. I am still learning skinning. Maybe John can make a 2nd official version for dual display, Or someone who is better can make what I started better.
    Let me know and I can post it somewhere or work something out with John.
    FKA psptibby
  9. #279
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    Quote Originally Posted by bay350z View Post
    I have interest in dual displays for this skin. Particularly Lambo's RRVLC plugin.
  10. #280
    Sep 2008
    Quote Originally Posted by Jebus View Post
    JQFletcher
    ...JJG
    Thanks Jebus. So did I bump that button to bring up the other list or does it automatically switch them based on GPS location or something?
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
