View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 29 of 246 FirstFirst ... 19202122232425262728293031323334353637383979129 ... LastLast
Results 281 to 290 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #281
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by meisner View Post
    Is there a way to force a Wifi connection? I saw the topic in the help entitled, "How do I Connect to the Internet through the skin?" but that is for dial-up. Nothing for wifi. I know there was a plug-in to manage the WLAN connection. Is that completely gone? ...for now???
    due to difference of opinons between El Camino and John & Blue on the path John & Blue have taken for Donations , El has with drawn , his wifi PI, to be release within the DFX installer,
    Wifi PI will be available on my web site some point tonight www.carputer1.com, free to download , with option to donate if you wish ...
    BUT!!!!!!
    if you come across any issues with His Plugin within DFX , he will not support you in any Errors found......
    I suggest if you do have issues , use the test skin in Carwings skin , if the issue is still there then El will look into the issue
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #282
    Mar 2007
    Nashua, NH
    Ya, I knew about ElCamino's Wifi PI being pulled. But there is nothing else out there to initiate a Wifi connection? I hadn't used it in a while, but the last time I played with ElCamino's PI, it didn't seem to work reliably...so I didn't spend too much time with it.
    I just want a skin button to cause WLAN stack to attempt a connection now. I would press this when I enable wifi tethering on my iphone. Instead of waiting for some "random" amount of time for Windows XP to scan for available WLANs again.
  3. #283
    Sep 2003
    Thousand Oak, Ca
    Does the OBDMPG screen require the no longer supported OBDMPG plug in. The link no longer works.
  4. #284
    Dec 2008
    i downloaded the wifi manager from the auto app mart and it installed and worked just fine. i still dont even know if its the plugin were not supposed to use, because the developer link is broken. so whatever for now
    ive been a slightly annoyed by how slow my truckpc seems lately. dfx5 on winxp feels a lot slower then dfx4 on win7 did. i dont know if its the os, or what. im also thinking about upgrading my cpu just to get better speed out of the voice recognition. i have it working better then i thought it would, but its not quick. sometimes after a command it might take 3 or 4 seconds just to figure it out, then another second or two to unmute the system.
    who knows, it might even just be some flash problem....
  5. #285
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    IMHO, RideRunner + DFX5 + Voice Recognition + FLash + GDI Sub System + Whatever Else, needs at least a 2 GHZ Chip (Single Core) and decent Graphics to function at an acceptably fast speed for a Car PC. Theres a lot of disk activity, so SATA is the way to go if using a normal hard drive...
    ...JJG
  6. #286
    Mar 2007
    Nashua, NH
    Quote Originally Posted by trader007 View Post
    Cool...thanks for the info. I will try it out again.
    I found a section in the DFX help file, and a text file in the DFX5\Helper Files folder called Windows Optimizations for the CarPC, that I am going to use to fine tune the performance of the car PC. Seemed to have a number of useful tips.
  7. #287
    May 2005
    Monterey, CA
    Quote Originally Posted by mnwcsult View Post
    I am getting a popup from DFXSpeak, cannot create object. Any ideas?
    I am getting the same active x error on startup of the skin. I think it has something to do with the greeting and some required dll to be registered or something.
    FKA psptibby
  8. #288
    May 2005
    Monterey, CA
    Quote Originally Posted by Jebus View Post
    ...JJG
    I have it on a 1.2 VIA with a CF flash drive and it runs pretty good, but i selected a non flash logo and haven't setup voice yet. I have everything ready except I need a good Mic with noise cancellation. Looking at the one in the mp3car store.
    FKA psptibby
  9. #289
    May 2005
    Monterey, CA
    Quote Originally Posted by jeffreyd_tx View Post
    I have interest in dual displays for this skin. Particularly Lambo's RRVLC plugin.
    Cool, I still have some work to do on it. Do you have any experience working on skins?
    FKA psptibby
  10. #290
    Jul 2006
    Make sure debugging is disabled for rrvoice. That'll definitely drag your system down
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
