View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 30 of 246 FirstFirst ... 20212223242526272829303132333435363738394080130 ... LastLast
Results 291 to 300 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #291
    Dec 2008
    jebus, i have a 1.8ghz conroe 1 chip. i think youre right... the speed is good enough but now with the new features its starting to show its limits.
    nice thing is i probably can run any 65w s775 chip so finding a dual core upgrade should be easy.
  2. #292
    Feb 2006
    Quote Originally Posted by silvi4000 View Post
    Do you see higher CPU usage during night time recording?
    Try different encoders. The "K-Lite codec pack" installs some encoders you could try. It might depend on your camera model too. Im using a PS3Eye and get very good FPS and resolution with low CPU usage
    Hi Silvi4000,
    CPU usage is not a problem for my carpc, it's only about 25%.
    And I did use the FFDSHOW to be the codec when recording.
    Webcam is Microsoft Lifecam Cinema HD, which is capable of doing 1280x720.
    I saw this on Youtube, 1280x720 @30FPS. Any idea how to achieve that?!
    Thanks in advance!
    HD-5000 1280x720@30FPS during Nightime
  3. #293
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by mnwcsult
    I am getting a popup from DFXSpeak, cannot create object. Any ideas?
    Quote Originally Posted by bay350z
    I am getting the same active x error on startup of the skin. I think it has something to do with the greeting and some required dll to be registered or something.
    Are you two running striped OS's? Or, what OS are you running?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #294
    May 2005
    Monterey, CA
    I am running XP that is nlited. So sounds like I am missing a file. If u know which I probably can add it.
    Sent from my SAMSUNG-SGH-I897 using Tapatalk
    FKA psptibby
  5. #295
    Constant Bitrate overlander's Avatar
    Feb 2008
    Quote Originally Posted by JohnWPB View Post
    Make sure you do not have the MP3Art.dll installed and registered. If you do, it will use the album covers embedded into the MP3's. These are normally very small pictures, and when stretched in the skin will look really really bad.
    John
    I'm having this same problem, but I'm completely missing how to make sure mp3art is not enabled/installed. Can you point me to the reference or advise how to get rid of this?
    I also am having a seperate issue with DFX5. My system freezes when I make onscreen changes to some of the functions. Examples so fare are:
    1. with auto switch day/night is enable in the global settings, when the system tries to actually changes from day to night automatically, and the long notification popup ("night setting has been enabled...or something like that), the screen freezes with the notification bar up. requires reboot.
    2. in the mixer, when I try to make a change to one of the presets (ie pop, rock, etc), the notification bar pops up with "settings saved" and the screen freezes. requires reboot.
    since these seem to be related to onscreen settings changes, I'm assuming they are related. any advice on what to check? Didn't have these issues with DFX4. I'm running a normal version of XP home edition.
  6. #296
    Mar 2007
    Nashua, NH
    Quote Originally Posted by overlander View Post
    See post #2. Download the new TimeSwitch and put it in place. This problem was reported a while back.
  7. #297
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Hopefully we can get out both an updated installer and the assoc patch update, soon...
    Not easy when John is getting over the china jet lag and is now sick...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #298
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    probably the Mcdonalds lol....how he manages to eat a burger with chop sticks
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  9. #299
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Very nice...been busy of late, but pleased to see, then install this release. Got most of the personal kinks worked out, and the disclaimer on the front explains the issue with wifi-man...
    The imageviewer that's bundled though...It's reeeally not liking win7-64 for some reason, I've modified the skin.ini so now at least it actually embeds, it was set to embed "imgvwr" for the window title, which in mine should be "imageviewer". That a windows forms platform issue between 'em?
    The further problems may simply be the base RR itself, as the buttons aren't functioning for me. forward, back, slideshow. *shrug*
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
  10. #300
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, that is a known issue with the 5.0.3 release and has been already address..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
