View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 31 of 246 FirstFirst ... 21222324252627282930313233343536373839404181131 ... LastLast
Results 301 to 310 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #301
    Nov 2007
    Quote Originally Posted by monty9991 View Post
    i have a question about the startup greeting.
    I have installed the skin in my laptop running vista and i have a female voice for the greeting to say, and in my carpc its a male voice.
    how do i change male to female in my carpc?
    any one??
  2. #302
    Jul 2006
    any one??
    Go to "Speech" in your control panel, and under "Text to Speech", select a different voice.
    There are only a few to choose from, but you can purchase more. I highly recommend Neospeech's "Julie"
  3. #303
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    I'm also crossing my fingers for a new working wifi manager in DFX. Well now that we are on the subject of the Julie voice, is there anyway to make the start up greeting to start talking first and finish talking before your music resumes from last time used? The music starts first a bit, like 2-4 sec., music pauses then greeting kicks in, then music seems to skip ahead a little on resume. Not were it was last time I used RR/DFX. Is this normal? I never used greeting at start up until now. Maybe a setting in RRVoice or something in TTS? Thanx all.
  4. #304
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Something like that almost would need to be a new setting in RR, so that when it starts the player sets the RR PL, that it does a play followed directly by a pause, and then the skin could check if the setting is set, and if so, at end of the startup speaking, unpause it.
    This occurs because RR starts playing the PL before the skin start up routine has a chance to get far enough to pause it to speak, causing 3-4 seconds of music. Now thinking about it, there is a slight adjustment that we might be able to do that would hopefully minimize the music before the speech...will check into it.... Would be much more preferable to how you are describing how it should work.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #305
    Jul 2006
    While the subject of the system greeting is up spot the mistake,
    today was;
    Wednesday, October twenty-six, twenty-ten
  6. #306
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Can't figure-out how to justify-right the text on the main menu buttons?? When in development, there was talk about incorporating a setting that could left, center, or right justify the text - i can't seem to find that either (if it was indeed added).
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  7. #307
    May 2007
    Blue, great to know that this will be looked into Thanks. ----> Treetop, It's called DFXMenuJustify.txt file. I changed my button text to CENTER, I think this looks better. Just my opinion. Oh, and also if your using CNN NEWS like I do you can change the text to just NEWS in button editor and just have the button icon read CNN instead of it looking like CNN CNN NEWS. Just change name of icon to NEWS in button icons folder.
  8. #308
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by andygardner View Post
    today was;
    I think i know what you issue is...do you have the system start of the week set to monday verse the typical sunday, like most calendars? Thats is really the only thing that I could think of is why your the only one having this issue...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  9. #309
    Constant Bitrate overlander's Avatar
    Feb 2008
    Quote Originally Posted by overlander View Post
    John
    I'm having this same problem, but I'm completely missing how to make sure mp3art is not enabled/installed. Can you point me to the reference or advise how to get rid of this?
    I also am having a seperate issue with DFX5. My system freezes when I make onscreen changes to some of the functions. Examples so fare are:
    1. with auto switch day/night is enable in the global settings, when the system tries to actually changes from day to night automatically, and the long notification popup ("night setting has been enabled...or something like that), the screen freezes with the notification bar up. requires reboot.
    2. in the mixer, when I try to make a change to one of the presets (ie pop, rock, etc), the notification bar pops up with "settings saved" and the screen freezes. requires reboot.
    since these seem to be related to onscreen settings changes, I'm assuming they are related. any advice on what to check? Didn't have these issues with DFX4. I'm running a normal version of XP home edition.
    Got the auto switch working with the fix in the #2 post. My apologies for missing that.
    The press and hold saving of mixer settings is still freezing my system though. any ideas what's causing that?
  10. #310
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Not w/o looking at the code to what clould be hanging your sys
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
