View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 35 of 246 FirstFirst ... 25262728293031323334353637383940414243444585135 ... LastLast
Results 341 to 350 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #341
    Jul 2006
    I've got a Spacenavigator. It's got six degrees of freedom and two buttons you can map loads of actions to keystrokes, short/long press for each plane, different keystrokes depending upon how far you twist/push/pull etc. More than you would ever need.
  2. #342
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by GSRT18 View Post
    That would explain about the posts
    As for overkill, its relatively cheap, and i'd use it for volume control aswell as track select, it seems quite versatile.
    I will add that way back when I tried to go this same route, that there were driver issues. But what would you expect when using a "Apple" made product on a PC. I would have to unplug/replug it at least twice a week as it wouldn't be recognized either resusing from standyby or from a fresh boot. I know that they have since updated the drivers, but when i did last check em out..still same boat... unreliable. Buyer beware.... do some research
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #343
    Sep 2008
    I have another odd thing happening...regarding Garmin. When I click on Garmin off the main menu, it takes me to the Garmin skin, but the screen is black. So i click in a couple places and Garmin will then show but it will be a couple menu's deep meaning that it would seem that Garmin is up and functioning when I first go into but it doesn't appear on the screen until i click a few times. So I know its picking up the clicks because its navigating in the program but there is nothing on the screen.
    Anyone else seen that?
  4. #344
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    I just installed my Visteon HD Radio back in my ride and I'm having the same problem posted here----->
    Quote Originally Posted by Sicarius View Post
    Not sure if it's a bug or not but if I go from the HD Radio skin to the Internet Radio skin, Winamp stops (pauses?) and nothing plays no matter what "station" I select, plus there is no play button (bottom button for play/pause is blank and does nothing when pressed). If I go to the Music skin, I get my play button back and can then start Internet Radio playing.
    I didn't see any fix for this posted yet. Thanx.
  5. #345
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This is due to RR being skin source sourced, no actuall audio source. Example you go into the radio screen it stops the audio player and starts up your radio. you can navigate to any srcreen that is not one of the sources (audio/video) and RR will not switch sources, but if you go into one of those screens, it will switch to which ever A/V that screen is related to. This is also why you have no play/pause button status on the btn as the RR is not using the audio player as the current soure, goes with the inet station btn not working...
    This could be slightly adj in the skin so that when you go into this screen it also tell RR to switch back to using the audio player.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #346
    May 2007
    Cool, ok so this means that when I go back to the main menu screen from the hd radio screen my play/pause icon will show up again and my music will resume again were I left off from the last position? If that's what your saying, then what change do I have to do?
  7. #347
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Another thing for your patch list
    I have noticed (thanks to a question raised by RAWPWR) that the proper button command to go from the search screen to the camera screen is not being used, so if you select new presets the skin is not telling RRTC to update it's preset list.
    Please edit trafficam_search.skin and look for the following line
    B21,0,528,100.72,"RRTC||rrtc_refresh",
    and change it to
    B21,0,528,100.72,"RRTC_back",
    also
    edit trafficam_web.skin and look for the following line
    B21,0,528,100.72,"RRTC",
    and change it to
    Cheers
    E.
  8. #348
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    To get the Internet radio to work after leaving the HDRadio skin, you would need to go to the AUdio screen first. I will see about a workaround for the upcoming patch.
    Enforcer, all files corrected here per above post. Thanks!
    My Fiero Build Thread
  9. #349
    May 2007
    Excellent, thanks again.
  10. #350
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by RAWPWR View Post
    In the mean time, you can open the skin.ini in the DFX5 folder in notepad.
    Find this line:
    PHP Code:
    MenuExec_26=load;Internet_Radio.skin
    and change it to this:
    PHP Code:
    MenuExec_26=load;Internet_Radio.skin||SETSOURCE;AUDIO
    The only drawback is, that when you go to internet radio, your audio player will resume where it left off, till you choose a station. If you would just rather stop the audio completely till a station is chosen, you can change the line to:
    PHP Code:
    MenuExec_26=load;Internet_Radio.skin||SETSOURCE;AUDIO||STOP
    (I had to wrap the lines in PHP code, as the forum breaks apart long lines with spaces, thus corrupting the code)
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
