View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 36 of 246 FirstFirst ... 26272829303132333435363738394041424344454686136 ... LastLast
Results 351 to 360 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #351
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Internet Radio Stations Working
    Quote Originally Posted by RAWPWR View Post
    Wow, this is a tough one. This should of worked with settings I posted. The only thing I can suggest is go into plug in manager and disable and then re-enable again, then restart RR. Again, good luck. Sorry that I couldn't help more. Maybe someone else on this forum may chime in and help...
    I finally got the Internet radio station info to show up in DFX5. I had to manually edit the skin.ini file to set internetradiolabels to true although in plugin mgr it was set to enable and internetradiolabels showed on in global settings. I had to change a few other settings there as well because my settings were not saving correctly using the DFX Menu editor button.
    I hope this helps someone else.
    Gee
  2. #352
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by navputer View Post
    Ok, I just verified that the Global settings screen, when changing the toggle for enhanced Internet radio labels, does save the correct settings in the skin.ini. Switching the toggle off saved false to the skin.ini, and toggling on set it as true. So that part is working as expected.
    what were the "few other settings" that you changed, as that may be the key?
    My Fiero Build Thread
  3. #353
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Been trying to resolve several issues here. I think my questions were lossed in the mix of the initial release posting rush..
    That said. I till get no date or time no matter the menu layout i choose. Flash is up to date. Also, when i change the menu layout, it takes a restart of rr to actually change.
    RRvoice indicator not working, nor does the "listening" picture pop up.
    Speak greeting at startup doesnt work. When i test in global settings all is well however when rr starts i get nothing.
  4. #354
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Did you turn on the time/date opt in the menu layout scrn?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #355
    Nov 2007
    PA
    O...M......G.
    These still yet to be resolved though...
  6. #356
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Dougw133 View Post
    O...M......G.
    You need to delete your existing RRVoice folder in RR\Plugins, then reinstall DFX. Once DFX is reinstalled move rrvoice.ini from the DFX plugins\rrvoice folder to RR\Plugins\RRVoice folder. If you've made changes to your rrvoice.ini, you should back that up. Commands are now in DFX\Plugins\RRVoice\menu.ini rather than rrvoice.ini so that is the file you need to edit to modify commands.
  7. #357
    Jun 2010
    Ok, so i just paid for a licence for DFX5......
    It said in the loader description:
    This patch changes the DFX5 splash screen to one to match the skin. It also allows you to change the splash screen to any image that you choose.
    I wanted to changed the current DFX5 load screen, to an image i have made but can't see how to do it? Or was it in the patch i downloaded and just missed the option from being too excited.....
  8. #358
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Quote Originally Posted by GSRT18 View Post
    open DFXfolder your looking for splash.jpg or png thats the 1 you want
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  9. #359
    Jun 2010
    Awesome, found it. Splash.jpg. Cheers carputer1.
  10. #360
    Jan 2007
    DFW Area
    Quote Originally Posted by JohnWPB View Post
    Sorry for responding so late on this....
    The other setting changes in the skin.ini was for other plugins and not InternetRadio one. However, I did change the setting mentioned above for WinAmp ("read metadata when files are played or viewed....")
    I changed other plugins like trafficcam, slingplayer and RRcam (MenuExec and MainMenuExec) that didn't seem to save my changes in the DFX Button Editor. I had this happened before trying to save (File/Save-Exit)No biggie... I can do it manually if need be.
    Thanks for your help...
    Gee
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
