Hi
When I installed everything was already checked except mappoint so it is not that....I wonder why I don't have this advance seaech option..?
@mbco
You need to make sure to check "RRMedia" in the select components window during the DFX install. It sounds like you didn't do that and RRMedia wasn't installed.
Hi
What you need to do is add that setting as it wasn't present in the ini file. Open up the file and add the part in bold .
# This adds the song to the database if not found with no rating.
# Would be good for creating a list of unrated song to go though at a latter time
# (True/False, default is off)
[Database Settings]
DiskLoadingSplash=False
Autoaddsong=False
VirtPl=True
AdvSrchMode=false
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Ive been searching through the posts and have not seen anything yet on this issue. Whenever I click on the sync files button the cpu loads up but nothing happens im running the latest RR and running the 11/1/2010 version of DFX 5.0.3 if someone could point me to the post or tell me how to fix this.
The Sync Files in the skin uses Enforcers RRUpD8 plugin. You need to download and install it from his website. It is a great plugin, and allows you to set paths to sync files between your home and CarPC.
My Fiero Build Thread
hi john,
in post 398 i ask you and blue
hi john and blue,
is it possible to get the source of your ...ColorPick...flash file ? the one you also use in the dfx3 version.
the one i try to work in my skin makes me not happy, the cycle of it brings my system into slow motion.
thanks for it.
regards GF-ler
Thanks for all your help so far with the search functions I will add this line into the ini file in the morning... are you also able to help me with the other question which was what to do with the delete song files that were posted around page 8 as I really would like to start deleting the rubbish songs from the many many compilation albums I have......cheers
That will be available in the update patch, and will be built in verse the separate exe that was posted.
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
That will be great blue i am looking forward to that....] I hope its soonish as I have ocd when it comes to my mp3's and marking them 1 star for now until you release the update....
Thanks so much for everything so far....
Why - Why - Why! just installed the skin in the truck and it refuse to pick-up the backgrounds; it don't show the BG pictures in the browser and neither does it pick-up the backgrounds when changing themes. The background is always black.
Running the 11-01 RR and just updated flash (in the truck). DFX4 is still working fine (i can change BG at will)
The skin work fine on my test laptop; i can't figure-out what the problem is; actually, i'm just being lazy and hoping for a spoon feed..![]()
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
