View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 43 of 246 FirstFirst ... 33343536373839404142434445464748495051525393143 ... LastLast
Results 421 to 430 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #421
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Bad monkey!
    The only thing it could be would be that your backgrounds are not in the default location or you have a backgrounspath setting thats not pointing to the proper location. 5 makes use of the 'backgroundspath' in RR. A debug log might help you or us figure out your probably simple solution.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #422
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Bad monkey!
    No doubt it is simple but I'm drawing a blank; it don't help that i have no clue how to read the debug. Please help..
    It's probably something staring me right in the face..
    Attached Files Attached Files
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #423
    Sep 2009
    @dawn
    The picviewer that came w/ the installer was an older version and we didn't catch it
    till after the fact. Its already noted and added for the update patch
    when we release the patch.
    Thanks for the heads up....
    switched a few things around and got it working till the
    update/patch comes along!
  4. #424
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by treetop777 View Post
    Well, the log didn't really tell anything useful. Your gonna need to see what your RR backgroundspath variable is set to as that is where your problem is occurring from.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #425
    Sep 2006
    War-Town, GA.
    It is something simple but i just can't find it! I checked all the paths and they point the BG folder. The funny thing is when i switch to DFX4, everything is fine. Do they (DFX4/DFX5) have different BG code?
    I'll reinstall and see what happens..
    Thanks for the help.
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  6. #426
    Raw Wave
    Jun 2002
    Virginia
    Treetop,
    I believe this probably is simply a matter of making sure the background images are on your computer and making sure RR/DFX knows where to look for them.
    Check to see if you have a bunch of jpg files in Riderunner\Backgrounds. If not, that is likely your problem. If they are there, open RRConfig, go to skins and in the background Picture Path section make sure Image is chosen and point to the path where the image files are.
    During the DFX installation a window appears asking about installing additional components. One of them says something like "Additional Background Images." If you can't find the image files you may want to reinstall and check that box, whose purpose, I believe, is to install the image files in the default location. Do you, by the way, have RR installed somewhere other than c:\Program Files\Riderunner?
  7. #427
    Raw Wave
    Jun 2002
    Virginia
    IGuidance 2011 Pre-Release Sale
    To all you folks using iGuidance with the skin. Inav is having a pre-release sale of iGuidance 2011 for $69 for registered users. This is $10 off the regular registered user price. That's not a huge break, but every little bit helps. There's not a lot new in this version, but it does include 2010 maps, which is good for me because my iG 4.0 maps are getting a little long in the tooth. You can check it out here.
  8. #428
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Does this mean that this version of Iguidance 2011 will work with DFX5 out of the box? The reason I'm asking this is because right now some of the buttons in the iGuidance GPS screen like 3D, POI, etc. just don't work. Nothing happens, but works outside of skin. And also the add on for iGuidance which was made for DFX4/IG can I use this for 5 and future versions of DFX? I did try the add on in 5 but it does not change from day/night automatically. Thanx
  9. #429
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by RAWPWR View Post
    Not sure why your buttons aren't working, but iG 2011 shouldn't be any different - better or worse - in terms of its interaction with RR and DFX than previous versions of IG.
    What addon for DFX4/IG are you referring to? iG works greats with RR/DFX without the need for addons.
  10. #430
    Jan 2010
    Hi... I have added that line in the .ini file and it is now working thank you.... can I ask if its possible to search for a partial name? I.e. I have to type 30 seconds to mars for a result and if I search for mars I get nothing... obviously whilst driving.I like to keep typing to a minimum....thanks again
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 05:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
