View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 46 of 246 FirstFirst ... 36373839404142434445464748495051525354555696146 ... LastLast
Results 451 to 460 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #451
    Nov 2008
    Also, John or Blue, I'm having problems mapping button controls with the CarPc JoyconEX specifically to DFX (I can get them to work outside of DFX with say winamp, however). How can I set up the bottom buttons (menu, previous track, forward track, play/pause, etc.) to work with the keyboard so I can map my Sony RM-X11M to those keyboard buttons? In other words, how do I set up say the "B" key on the keyboard to serve as the bottom button for "skip track", "V" for "previous track" and say "X" for "play/pause"? I'm assuming there is a way to do this by putting in commands in the extetbl.ini or something, right?
  2. #452
    Nov 2008
    Okay thanks blue
  3. #453
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Add these to your keytbl.ini file:
    PHP Code:
    /, 'b' key for next track
    66
    ,"RRNEXT"
    /, 'v' key for the prev track
    86.
    "RRPREV"
    /, 'x' key for play/pause toggle
    88
    ,"Play"
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #454
    Nov 2008
    Sweet thanks. You da man! :-)
  5. #455
    Jan 2010
    J
    Quote Originally Posted by mbc0 View Post
    Hi,
    I have attached the files to see if you are able to help me to a simple search for part of an artists name.....
    Many Thanks
    Martyn
    hi.blue have you had a chance to look at the files I uploaded? Cheers
  6. #456
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, you set the new setting wrong, I said to set it to false to keep the search method like the previous version. You had it set to true, which was the same as the default if the setting isn't found.
    AdvSrchMode=false
    Then searching under say artist 'mars' brings up any thing that contains the word 'mars' in the artist name, and same for any other other search opts
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #457
    Jan 2010
    Doh! I am such an idiot, I read what you meant wrong! (It's like texting someone, you can mean something that can be taken the wrong way) Thanks Very Much Blue, I will go and do that in the car now....
    Can I ask how far away the update is with the delete song button please?
    Many Thanks
  8. #458
    Low Bitrate jparks27's Avatar
    Feb 2006
    Maryland
    I'm having random CPU spikes, text is randomly disappearing, screens are not updating properly, some take a number of seconds to display... Updating gps info on the speedo screen is bout 5-30 seconds delayed....
    dfx4 worked perfectly fine..consistent 1-2% cpu load even under heavy use...
    I'll be heading back to dfx4 on my daily driver and tinker with dfx5 on my dev system...
    Edited to add: fresh install of XP, fully updated drivers/flash/directx. fresh install of RR/DFX5, Intel PDC T5850, 3GB DDR2, 250GB HD - so no corruption/speed issues.
    Thanks for all the hard work guys! If there is anything you want me to test out, I can.
  9. #459
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Can we assume that fresh RR is Oct or newer release?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #460
    Feb 2006
    Maryland
    newest release - all fresh downloads..
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
