View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 52 of 242 FirstFirst ... 2424344454647484950515253545556575859606162102152 ... LastLast
Results 511 to 520 of 2412
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #511
    Dec 2007
    That is more than likely the RRMedia plugin. go to your music path root and delete the RRMediadb.db file, that is the RRMedia database. You should then be able to attempt to rescan it from a fresh start.
    Thanks man. . I'll do it right away. .
    Edit: That was the issue indeed, works like a charm now..
  2. #512
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by jarepa View Post
    Correct me if I'm wrong but this is a creation of ELCAMINO and based on the current disputes that are between developers looks like a different solution will be required to have this working.
    I can add it myself (ElcosMenu) and get it working correctly, however I choose to respect ELCAMINO wish of not using any of his creations under DFX5 and I looked for a different solution.
    thanks
    Actually, the DFX skin is using a custom AutoIt app that BlueZx3 and I wrote to handle the keyboard. This was written before ElcoMenu came out. I will have to look at the code and see what is going on. I think it is a simple matter of positioning.
    I wrote the code, as a few of the other overlay things that I tried were really sluggish. I basically used my old code that I did for the overlay of the zoom in / zoom out on the radar screen, and the "exit button" for the full screen GPS overlay buttons. The keyboard just has a LOT more buttons
    My Fiero Build Thread
  3. #513
    Sep 2006
    Lancaster PA
    Another probably simple task.
    Sirius works fine, in Line In.
    However, I have the following issues.
    1. How do you stop the Sirius radio? For example, I want silence in the car, nothing at all playing. Yes mute works, but that isn't the point.
    2. If I have Sirius running, and I want to switch to internet radio for something else, Internet radio doesn't stop Sirius(or probably just mute line in) and play. If Sirius is not playing first, I can go into Internet Radio and play anything.
    If I go out of RR and play the m3u file with the address it plays fine in WinAmp.
    It's been a couple of years since I have worked with RR, so I am a bit rusty.
    Thanks for any help.
  4. #514
    Jun 2002
    Virginia
    Hard Shutdown Zaps Menus
    I'm wondering if anyone else is having this issue. Every now and then I need to do a hard shutdown of the computer. Sometimes when I do while RR/DFX is loaded when I reload RR with DFX (i) none of the menu labels on the left and right side of the menu screens (all 4 menus) appear, and (ii) none of the menu buttons on the left and right side of the menu screens (all 4 menus) work, though the buttons at the bottom of the menu screens show the labels and execute the proper commands. This has happened happened to me about a dozen times. Interestingly, all of the menu functions, and the entire skin for that matter, continue to work when I issue the commands with RRVoice, but the menu buttons do not work or show labels.
    John and Blue, is there a file that if corrupted during a hard shutdown could cause the menu labels not to appear and the related buttons not to work?
  5. #515
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, that would be the skin.ini has the settings for most of the skin. Both the button label text and the cmds that the buttons get assigned to. better question is what have you been doing to restore the skin when this happens? Reinstall it, or copy from a backup copy?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  6. #516
    Jun 2002
    Virginia
    Thanks, Blue. System Restore has worked a couple of times to bring it back. When that hasn't worked, I've used Clonezilla to restore a previously saved image of my C drive. I'll make a backup skin.ini and throw it in if I have trouble from now on.
  7. #517
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    My RR greeting stopped working for no reason, but works when I test it, but not on RR startup. How do I fix and keep it that way(don't want to keep running "System Restore" for this issue)!!!
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  8. #518
    Newbie thinkfta's Avatar
    Jul 2009
    Just installed DFX 5.0.3 and really like it. Much improved and easy to work with.
    I donated and downloaded the patch, then ran it.
    I'm still getting the nag screen. Any auggestions? So far, this is the only thing that's not working for me !!!
    Thanks,
    Thinkfta
  9. #519
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by thinkfta View Post
    Thanks,
    Thinkfta
    I'm using the version release before they fixed the "nag splash", that I hacked. The hack is listed in this thread in an earlier post. I doubt it will work on the new release, cause I think it has more than one "nag splash", but it should give you ideas for a workaround(can you say "read only").
    If I were you I'd PM the developer and ask him how to disable it....you did "DONATE", so I don't think he should have a problem....Just don't post the fix, or you may get "Banned"!!!
  10. #520
    Sep 2009
    Philadelphia, PA
    By the way, my startup greeting no longer works since changing the user default GUI to RR...WTF!!!
    Other than that, all is good in the "300".....
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
