View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 53 of 246 FirstFirst ... 3434445464748495051525354555657585960616263103153 ... LastLast
Results 521 to 530 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #521
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by thinkfta View Post
    Just installed DFX 5.0.3 and really like it. Much improved and easy to work with.
    I donated and downloaded the patch, then ran it.
    I'm still getting the nag screen. Any auggestions? So far, this is the only thing that's not working for me !!!
    Thanks,
    Thinkfta
    It sounds like there were some files that didn't get updated. We are trying to get the patch out and a updated Donation installer that should not give users trouble like your describing.
    Sorry about the delay on the hold up...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #522
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    Blue ZX3...is there anyway to resolve my startup greeting problem without reinstalling DFX5? Will "chkdsk" revert my user GUI edit?
    By the way, this skin is awesome....
    Thanks in advance!!!
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  3. #523
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    No, will not. I'm not certain why changing the windows shell to RR would effect that. Its not something I do in my setup but would have to try, to see if your issue can be reproduced, otherwise it would be something more specific to your system/setup.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #524
    Sep 2009
    Philadelphia, PA
    Gonna run "chkdsk" then and see what happens. I have noticed, by the way, a decreased boot time since changing the user GUI. Much faster boot up and a more embedded feel. I recommend the GUI edit.
    Here is the DETAILED fools proof method for changing the user default GUI...can't fubar your system if you follow the directions to the letter in the 4th post...guaranteed!!!....
    (UPDATE:Solved)Need help changing XP GUI!!!
    And the fools proof method to auto starting apps in RR on the edited user logon that the skin won't launch....
    http://www.mp3car.com/vbulletin/winn...ml#post1423913
    Hope these babyfied instructions helps someone else out there!!!
    PS: Let me know if the issue is reproduced when you get around to trying the GUI edit Blue ZX3!!!
  5. #525
    Newbie thinkfta's Avatar
    Jul 2009
    BLUE ZX3,
    OK - Sounds good to me - long as I don't have to re-donate!!!!
    Thinkfta
  6. #526
    Mar 2008
    WPB, FL
    Replace your RRMediaDb.exe with this one(save w/o the .txt ending) and turn on the RRMedia debugging. Instructions Here
    Quote Originally Posted by Rev1979 View Post
    Debug files attached
    Blue,
    did the debug files gives any hints to my resume issue?
    VIA EPIA-MII12000 M2-ATX 160W DC-DC WinXP Pro SP3 1 Gb Mem 250GB HD Xenarc MDT-X7000 BU-353 Weather-proof GPS Receiver iGuidance D-Link DWA-130 RideRunner (08/11) DFX4/DFX5.1
  7. #527
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Not exactly, it is getting the correct track/time from RR to use for saving but there isn't enough debug logging I think to see further into the issue. I don't know if it not being saved correctly or being pulled/sent to rr wrong. I will continue to look and add some extra debugging to see why its not working correctly for you in yet another updated exe.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #528
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    She's working fine!
    Not using near as many features as she has but she's working fine. Just discovered how to tether the computer to my phone so i suspect a whole new world will open-up (weather, internet radio, web browser) - or more bugs!
    often folks just post about problems - just wanted to break that cycle.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  9. #529
    Newbie flomas's Avatar
    Sep 2006
    Los Banos
    DFX 5.0 Splash Screen 800 x 480
    Hi Guys,
    I searched and search and haven't been able to locate anything on this ,
    I'm using a Mimo 720-S USB monitor and when I load up DFX 5 the splash screen is cut off.
    I'm running 800 x 480, is there anyway to adjust this..? It's not a big deal really. As I don't usually plug the monitor in until the puter is up and running and don't see it usually..
    But when I do.. It's annoying..
    Anything ... ?
    -=FlomaS=-
  10. #530
    Nov 2009
    Australia
    Quote Originally Posted by JohnWPB View Post
    Actually, the DFX skin is using a custom AutoIt app that BlueZx3 and I wrote to handle the keyboard. This was written before ElcoMenu came out. I will have to look at the code and see what is going on. I think it is a simple matter of positioning.
    I wrote the code, as a few of the other overlay things that I tried were really sluggish. I basically used my old code that I did for the overlay of the zoom in / zoom out on the radar screen, and the "exit button" for the full screen GPS overlay buttons. The keyboard just has a LOT more buttons
    Does this mean that the Garmin OSK transparency issue is definitely on your list of 'Things to do' John??????????
    I love your skins, but the OSK issue is the only thing stopping me from moving my PC from my desk, into my car! As long as I know that you are aware of the problem and are working on a fix, I'm prepared to wait patiently.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
