View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 54 of 242 FirstFirst ... 4444546474849505152535455565758596061626364104154 ... LastLast
Results 531 to 540 of 2414
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #531
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by flomas View Post
    Hi Guys,
    I searched and search and haven't been able to locate anything on this ,
    I'm using a Mimo 720-S USB monitor and when I load up DFX 5 the splash screen is cut off.
    I'm running 800 x 480, is there anyway to adjust this..? It's not a big deal really. As I don't usually plug the monitor in until the puter is up and running and don't see it usually..
    But when I do.. It's annoying..
    Anything ... ?
    Ya, you simply have to squash the splash.jpg as RR does not scale it like it does with the skin.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #532
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    S&T's flickers when in full screen mode in RR, making it unusable in full screen mode. Has anyone figured out how to enable S&T's to go into full screen mode inside the RR skin without it flickering yet?
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  3. #533
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Thumbs up Update on the patch and new features
    Ok, got a bit of time to work on some stuff in the skin. The patch is coming along nicely, and Blue has been working on that. It will update the skin to the latest version, and will make a backup of any files changed when it is applied. This way, of you have made any changes to the skin, they will not be lost. You can just copy over your changes from the backup folder to the main skin files.
    Next, I have been working on making the Internet radio skin a LOT better With Internet becoming more accessible in the car, it is a great feature to have.
    The main Internet Radio look has not changed, but there is a lot of new stuff "under the hood" so to speak. When you press and hold any of the buttons, you are presented with a genre list in the left of the next screen. Selecting a genre from the list, will show the stations for that genre on the right. Selecting one, will immediately start playing that station. If you like it, going back to the Internet radio screen, the button you pressed and held, will now be the preset for that station. There are around 300 stations to choose from. If you want to add one of your own, you can open the "StationsList.ini" and add the name and URL for the station under one of the genre sections. When you start RR, it will then be available under the genre that you added it under as a choice for the presets.
    Some of the station names are long, and will not fit completely in the button area. I got that covered Simply press and hold the button and choose "Rename" from the pop-up. You can then edit the station name to anything you like.
    As stations come and go, I will try to keep a current list of radio stations. Simply copying a new StationsList.ini into the folder will be all that is needed to keep everything up to date.
    Here are a couple of screen captures:
    My Fiero Build Thread
  4. #534
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by locs4dayz View Post
    The best way to fix that is to create a clipping area in the S&T skin. Check out This thread by Guino in the Stickies, the last paragraph titled: "Flashing of Embbeded applications"
  5. #535
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    do something about that select label lol...
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  6. #536
    Jul 2008
    London
    My DFX is running fine. However, in the background there is the following error:
    DFXSpeak
    Run-time error '429'
    ActiveX component can't create object.
    The greeting message doesn't play, I have disabled it, but I still get the error.
    Any suggestions? I'd rather have the greeting enabled, but its not the end of the world if its not.
  7. #537
    Dec 2008
    wow thats awesome john... internet radio is the best part of my carpc, but it was always troublesome to keep buttons updated and links working.
    thanks a million!
  8. #538
    Oct 2007
    Quote Originally Posted by JohnWPB View Post
    Hosting the file somewhere with version information would be the best to keep it updated. The CarPC already has to have internet for InternetRadio to work so getting updates via internet shouldn't be a problem.
  9. #539
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That is a GOOD idea'er.....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #540
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Something my skins and plugins have been doing for quite a while with certain files
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
