Well, yippie ki yeah, for you then... :rolleyes:
Printable View
Great work with internet radio John! No more hunting for good rock/comedy stations anymore. And also, Blue are you still thinking of adding the record button option to internet radio? This will certainly make the internet radio shine! :o Thanks.
I don't think that will make it to this update, but i have just done some quick tinkering and foresee this being fairly easily added...thinking as a seperate PI as not to hard code it into this skin only.
Cooool:cool:
Fixed.... I just removed it ;)
It is not needed, as soon as you single click / tap on a genre on the left, the stations for that genre appear on the right. Same goes with tuning, just tap a station on the right and it starts playing. If you tap the wrong one, just tap again on the one you want. Once you hear a station you like, hitting the menu goes back to the preset screen, with the station set on the button you pressed and held.
Could this be a BUG? I just updated the newest 12/05/10 RR and now it looks like the slider bar above the bottom buttons leaves some artifacts that stay and don't disappear until I restart RR. Also the button on the bar gets larger/expands when I hover over that area. Was fine until RR update. :confused:
The slider is larger than normal too. Uninstall RR from the add remove programs of windows and reinstall RR. Happenedn to me too. That was the fix.
General advise. I always do this when I see weird things after an update install.
Slider problem here also after latest RR update
