View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 57 of 246 FirstFirst ... 7474849505152535455565758596061626364656667107157 ... LastLast
Results 561 to 570 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #561
    MySQL Error
    Oct 2004
    hehe, i figured it out, based on a OLD OLD OLD OLD skin, the origional mediacar one
    which used all the features of the sliders (since our newer skins didnt)
    and figured out the DOCUMENTATION in RR is backwards
    so i sorted it, and now the update is posting soon
    and you can leave ur skins alone...
    there is a bounds check, so at least if u try to make the image area of the slider outside the button area, it caps it to button area
    it also wont hurt if u changed them!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #562
    Constant Bitrate overlander's Avatar
    Feb 2008
    I'm having an issue with the star playlist buttons that are in the ratings popup window. I just recently reinstalled RR (latest) and DFX5 (latest) to resolve some issues, and rebuilt my media database. I was having issues with activating the star playlists (ie 5 star playlist) with a com error popping up, and then bizarre uncontrolled scrolling in the browse window. this is now persisting, and my guess is there is some resilient and corrupt file that the star playlists referred to. If I'm right, where do I find them, and rebuild them? When I rebuild the database by the way, the import ratings playlist task fails.
    Anybody?
  3. #563
    Jan 2010
    Hi mate....i am new to this software so sorry if I an wrong but I am very sure there is a separate ratings file in the root folder of your music path along with the databade file....maybe you can delete it as it will have nothing to import when rebuilding your database then......
  4. #564
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The importing playlist "task" is only there for two reasons, 1) it would try to add ratings to songs from the older song rating plugin that sonic made ages ago if it found any "x star.m3u" playlists while scaning for media, 2) upon a freash scan where user only deletes the db, it will readd the previous ratings back the songs, using the 'rate.in_' backup file. I will check that issue with the com err on rating playlists, I do know that I seen that same err and am pretty sure that i fixed it (or did i completely for get about it?). Anyhoo, I'll recheck it and get it taken care of with v2.0.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #565
    Jun 2010
    Ok guys. Had my setup all going, was a bit slow between skins and awaiting voice commands, so reformatted and starting from scratch again. So far so good. Until....
    This time when i've installed the latest DFX, it seems I've hit a "Feature" that didn't occur last time. Whenever RideRunner loads up with DFX skin, it automatically goes to the "your system is locked" screen. Any ideas how to fix this? I'm still looking around.....
    Any help would be greatly appreciated, otherwise I guess i'll try reinstalling the skin for a 3rd time....
  6. #566
    Jun 2010
    Nevermind, found it. For those who have the same problem:
    Inside EXECTBL.INI within the skins\dfx root dir:
    Under commands executed on initialization delete |relock|
  7. #567
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Or you could have just typed 1234 and it would have not come back up till you locked it again. Hint: by clicking where the "Album:" label is, is how you lock it...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #568
    Nov 2008
    When I started up my carpc today, this is what DFX looked like. Subsequent restarts didn't help. Anybody know what may have happened and how to fix it? Thanks...
  9. #569
    Raw Wave
    Jun 2002
    Virginia
    You have corrupted your skin.ini file somehow, probably as a result of a hard shutdown. It has happened to me a few times. I now keep a backup of skin.ini to throw in if it happens. Before I started doing that, I had some success with system restore bringing it back. You might want to give that a try.
  10. #570
    Nov 2008
    Quote Originally Posted by kbreeden View Post
    Okay cool, I'll try that. Thanks...
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
