View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 6 of 246 FirstFirst 1234567891011121314151656106 ... LastLast
Results 51 to 60 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #51
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by meisner View Post
    This sounds very interesting...is this utility available? I could definitely use this tool with my music collection (especially when some random country song comes on that my wife put in the music collection!!)
    There is no 'Delete wife plugin'
  2. #52
    Nov 2009
    Just wanted to saw it shows both nag screens the 4.99 and the 9.99 Awsome skin.
  3. #53
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I think if you delete the splash.jpg from the RideRunner/Skins/DFX folder, the 4.95 one will go away and will default to the Ride Runner splash.
    Tidder
    Try RevFE
  4. #54
    Aug 2006
    Columbus, OH
    Quote Originally Posted by trader007 View Post
    same here. i cant even get garmin to start up unless i hit the gps button inside the music page. but even though the keyboard covers up the whole screen, it does still work and you can enter text in... you just cant see what youre entering.
    Same to me here and I believe I know why.
    To me looks like what is broken/not-working its the overlay or "ElcosMenu" that makes possible to overlay a picture/skin (like DFX5 OSK) over a program window.
    Correct me if I'm wrong but this is a creation of ELCAMINO and based on the current disputes that are between developers looks like a different solution will be required to have this working.
    I can add it myself (ElcosMenu) and get it working correctly, however I choose to respect ELCAMINO wish of not using any of his creations under DFX5 and I looked for a different solution.
    Actually I got around it replacing DFX5 OSK with a translucent adjustable keyboard that someone posted while back in the forums. Just changed the action on the OSK button to load the keyboard.
    The name is Free Virtual Keyboard and I believe you can get it at
    http://www.freevirtualkeyboard.com
    It does come with .ini where you can tweak color among another settings and it does support resizing. This is just a suggestion and I'm not encouraging or endorsing the use of this app.
  5. #55
    Constant Bitrate utd09bry's Avatar
    Sep 2007
    Dallas,TX
    Quote Originally Posted by jarepa View Post
    The name is Free Virtual Keyboard...
    I did the same thing for my install last week. It is MUCH more reliable than the OSK implemented with the skin overlay (mine would randomly disappear, and then I'd be stuck without a way back to the DFX menu). Not to mention, the freeVK method is usable as an OSK whenever you need it, not just for Garmin. I bound mine to popup with the push-and-hold on my griffin wheel.
  6. #56
    Jul 2010
    Confused, just install 5.0.2 and cannot run either IGO or garmin, where to write path for them? rr.ini, skin.ini, exec.ini???
  7. #57
    Mar 2007
    Nashua, NH
    Is anyone having a problem with the "Adjusting to Night Time Viewing" window going away after the skin switches? The task TimeSwitch.exe stays around and must be killed manually.
  8. #58
    Aug 2006
    Columbus, OH
    Quote Originally Posted by zenonek View Post
    Not sure if its the same bug that I found on the first 5.0 version install but check this out:
    Open the following folders RideRunner -> skins -> DFX5 then open the file:
    skin.ini
    scroll down and look for the line(s) that you need to correct:
    MenuExec_5=LOAD;Garmin_GPS.skin;!CDP_FIELD_WND;J:\GarminMobilePC\Que.exe;!CDP_FIELD_WND
    CHANGE DRIVE TO C: if you Garmin on that drive letter or the letter where you have it.
    NOTE: Your MenuExec number could be different. Just do a search for GarminMobilePC on your Notepad and correct with the right drive letter.
    Hope this will help.
    Mike K.
  9. #59
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    I grabbed it a while ago when LSX Void 3 was just out. So I don't know where to find it anymore. The delete song consists of a deletecurrent folder some confirm skins. I don't know if it's related but the "Remove Song" button doesn't work for me either. I never use it but was trying it out for my debugging. I don't have the source for the delete.exe so I don't know where it's breaking. Basically what happens is that I press the delete song button that I added, I get a confirm screen, select yes and then I get a Delete Completed but nothing happens. The only way I got it to work is if I add a new album and select delete song before I do anything else. I need this function!!! If anyone can help I would greatly appreciate it. I'm going to continue to dig in.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  10. #60
    Jul 2010
    skin.ini
    Mike K.
    Thank you
    That is what i did, still not working... only that my path is d:\GarminMobilePc\Que.exe
    Or maybe it has to be in program Files??
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
