Originally Posted by
Ramanator
Welcome to the Madness DorDroid,
Taken from the DFX helper file:
How Do I Use more than one GPS device?
If you are using a GPS Application, such as iGuidance, Map Point, Destinator ect, and want to use the gauges as well, you will need to use a com port splitter.
A port splitter allows you to take a single GPS receiver, and send that information to multiple virtual com ports for use by other applications. One of the most popular, is Xport. XPort3 is located where you installed the skin in the:
DigitalFX\Helper Files folder
Hope this helps.
