View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 60 of 246 FirstFirst ... 10505152535455565758596061626364656667686970110160 ... LastLast
Results 591 to 600 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #591
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Record Feature in DFX5
    I wanted to know if there is a certain way to setup the record feature in DFX5. I am able to see and select a record option (Line Volume, Mic Volume and Stereo Mix) but using any of those selections give me "Could not initiate the encoder". Are there files I am missing or need to setup to get this to work?
    RR Dec 12th Rel
    WinXP Pro
    Thanks for your help
    Gee
  2. #592
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    Did anyone have any problems with ImageViewer lately? For some reason bottom buttons don't work for next/prev, slideshow etc. I do see all my pics listed, so setup in ImageViewer Config.ini is correct, or did I miss something else? Also ImageViewer doesn't close after RR/DFX is closed.
  3. #593
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by RAWPWR View Post
    Known issue, and will be in the patch.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #594
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by navputer View Post
    RR Dec 12th Rel
    WinXP Pro
    This means that you are missing the codec that is being used to rec with. I did have this issue at one point but forget which one fixed the issue. Besides, at some point, dfx will have it's own audio recorder function, so that we can move away from using others plugins and dealing with issues that come with such.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #595
    May 2007
    Thanks Blue, so this will be fixed in upcoming patch, great!........ You and everybody here have great X-MAS holiday!!!!
  6. #596
    Oct 2010
    Thanks for the info. Updating as we speak.
    Quote Originally Posted by Ramanator View Post
    Welcome to the Madness DorDroid,
    Taken from the DFX helper file:
    How Do I Use more than one GPS device?
    If you are using a GPS Application, such as iGuidance, Map Point, Destinator ect, and want to use the gauges as well, you will need to use a com port splitter.
    A port splitter allows you to take a single GPS receiver, and send that information to multiple virtual com ports for use by other applications. One of the most popular, is Xport. XPort3 is located where you installed the skin in the:
    DigitalFX\Helper Files folder
    Hope this helps.
  7. #597
    Low Bitrate esko's Avatar
    Jun 2007
    Quote Originally Posted by DorDroid View Post
    Just curious, which map software do you us with DFX?
  8. #598
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Merry Christmas to everyone! I am headed out the door, and prob will not have a chance to get back on the computer till tomorrow evening, so figured I had better post now!
    My Fiero Build Thread
  9. #599
    Oct 2010
    I installed iGuidance 8. Xport seems to be working fine until my device looses power. When this happens I have to re-configure Xport, apparently it only retains its settings if the device is properly shut down or put into hibernation....weird. Do you know if this is common behavior?
    On another note - would you happen to know how I can include Canadian cities for the weather plugin?
    Quote Originally Posted by esko View Post
  10. #600
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    For the standard Weather plugin, go to weather.com and find the closest city to you that works.
    Enter that info into RRConfig.
    DFX5 extended weather may need other settings changed
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
