View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 61 of 246 FirstFirst ... 11515253545556575859606162636465666768697071111161 ... LastLast
Results 601 to 610 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #601
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I don't think that the extended weather needs any additional info, it uses the preexisting DL'd weather info.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #602
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    International weather cities
    I added a feature to DFX quite some time ago to help with multiple city matches, as well as foreign cities. When I put in "Miami" it would just pick the first match returned from Weather.com, in this case, Miami, Arizona.
    I pressed and held one of the preset buttons at the top of the screen, typed "Montreal" and pressed [ENTER].
    The following list then appears:
    My Fiero Build Thread
  3. #603
    Registered User
    Apr 2006
    Hello guys, i use dfx skin for rr and i have a problem with the navigation... I use destinator 7 and when i press the iquidance button it change the window and open the navigation page but when destinator opens it is in full screen and it cover the rr fully..... i tryed to chande the resolution of destinator ( i have 1024x726 screen and destinator 800x600) it covers the upperleft side of RR..... Is it possible to center destinator and word together RR and destinator?? Or i only have to use iquidance?
  4. #604
    Aug 2006
    So are there any fixes for being able to add an album to the playlist instead of having to go into the album and mashing the "add song" as many times as there are songs?
    Here are the errors I receive after performing a fresh install of RR and DFX 5.0.3, after complete uninstall, removal of ALL configuration files other RR\DFX related files...
    http://img208.imageshack.us/img208/5822/errorsk.jpg
    #1 I get when just opening RR with the file RRMedia.exe in RideRunner/plugins/RRMedia/RRMediaDb.exe being run. But when I rename it to something different (making it unable to run when RR is opened) it doesn't give me the error
    #2 I get when attempting to run a DB scan within DFX after creating a new button on the main screen
    #3 I get when trying to to go Music>Browser>Then when it tells me to create a DB file, i click "Build DB" and it gets to the "scanning and importing" step and just stops after giving this error
    Any advice or should I just go back to 4.0?
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
  5. #605
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by AntonisPsar View Post
    http://www.mp3car.com/vbulletin/rr-f...ad-runner.html
  6. #606
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by iNcArCeRaTiOn
    There is a button right next to that one that says "Add Album". A tap will add the album to the current playlist while a press n hold will clear the playlist first then adds the album selected.
    As far as your other errors, not sure as I have never seen those error descriptions #1&3. When you tried to do a complete fresh install did you a) delete your RRMediadb.db file in your RR music path, b) delete the 'RRMedia' folder in the 'Application Data' folder which is where all of RRMedia's written files are stored?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  7. #607
    Aug 2006
    Yeah, I believe so...but I'll try it again as it really irritates me lol
    Whatever uses the RRMediaDB will not work as the only way to get rid of those stupid errors are to rename the RRMediaDB file in the plugins\RRMedia folder
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  8. #608
    Jul 2006
    Quick question regarding monitoring temperatures. I've made a trick new aluminium case but it's getting a little toasty so I'd like to monitor operating temps in situ. I'm looking to change the CPU Load 'icon' on the main screen to temperature. Is this something that can easily be done?
    Searches have revealed speedfan might be a solution, which would be nice as I've been using it for a while on non-car systems so I'm familiar with it. However the helper file says it's no longer supported?
    Any advice would be mucho appreciated.
  9. #609
    Jul 2006
    Speedfan works fine for what you're trying to do. I actually did exactly that on mine, but my temp readout is where the star icons were.
  10. #610
    Jul 2006
    So I assume you used the RRskineditor. I've just had a mooch and the only code I can see the might be relevant is "TEMPX"? Didn't seem to do anything though.
    edit: oops, nevermind just being a bit thick. Took me a while to realise it might help to take a look at the Speedfan skin! All working now thanks!
    Ugh, even worse... it's in the helper file
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
