View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 62 of 246 FirstFirst ... 12525354555657585960616263646566676869707172112162 ... LastLast
Results 611 to 620 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #611
    Jul 2006
    Here's the case btw for anyone who may be interested, quite pleased with how it turned out! It's smaller than it looks, outer dimensions are 175x175x65 but it still packs an i3 540 and m4atx!
  2. #612
    Feb 2005
    Cali
    Happy New Year!
    Just wishing everyone a Happy New Year!
    Cheers
  3. #613
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    Hi, I'm trying to figure out how to maximize or restore from minimizing RR/DFX when using RRVoice. Does anyone know the voice command code so I don't have to tap screen to maximize? The command is Minimize=Minimize which works, so I tried Maximize=Maximize or Restore=Restore which does nada. I'm lost on this one. Any ideas anyone? Thanx in advance.
  4. #614
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by RAWPWR View Post
    Good question. I have also messed around with it a bit. I think it may not a command issue, but an RRVoice issue. The problem is that RRVoice can't be triggered/started when RR is minimized. Perhaps that's because RRVoice requires RR to be the active window and RR is not deemed active when minimized.
    Edit: I have just messed with it a bit more on my desktop. Interestingly, I can start RRVoice manually from the RRVoice window and control RR with voice commands while RR is minimized, but I can't trigger RRVoice with my trigger device when RR is minimized. I don't know what the RR maximize command is - or even if there is one - so I have not been able to successfully maximize RR after manually setting RRVoice to listen.
    I'm curious whether you're able to trigger RRVoice to listen with your trigger device when RR is minimized. Are you getting the little ding noise and muting of your music when you hit the trigger? I'm not.
  5. #615
    May 2007
    OK, but I did put the *RRVCON at the bottom of the list in the section of KeyTBL in RRConfig. Even when I have RR/DFX minimized I can still give voice commands (triggered/started) with no problems. So RRVoice does have focus, right? Very confusing. Thanks for your help kbreeden.
    EDIT: Did you go in RRConfig in the KeyTBL section @ bottom of list and put *xxxxRRVCON? And yes, RRVoice does listen and also I'm getting the ding noise, and it does mute when minimized when triggered.
  6. #616
    Raw Wave
    Jun 2002
    Virginia
    That means my trigger issue is separate from the maximize issue. Good to know. I'm using a mouse with RRMousetrap to trigger RRVoice. Hopefully, someone will chime in with an easy answer to the maximize command. Then I can sort out the trigger issue.
  7. #617
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    This is something that always bothered me with RR, and really became more of an issue with RRVoice. I worked with Mitch a couple months ago, and he came up with the solution. With a version of RR later than October 2010, you can now tell RR to monitor hot keys even while it is minimized / out of focus:
    The standard KeyTbl, if RR is in focus, to intercept the letter "a" as the trigger in the KeyTbl.ini would be:
    65,"RRVCON"
    To listen even if RR is minimized / out of focus, simply put an asterisk (*) in front of it like this:
    *65,"RRVCON"
    My Fiero Build Thread
  8. #618
    May 2007
    John, I've been using asterisk (*) which works great, but how do I maximize/restore from minimize with what command?
  9. #619
    Raw Wave
    Jun 2002
    Virginia
    I'm not sure what command I would use in KeyTBL to accomplish that with a middle mouse click rather than a keyboard key. I'm using a mouse and Jebus' RRMousetrap plugin for triggering. I think I'll move this part of the discussion over to the RRMousetrap plugin thread. Meanwhile, hopefully somebody can advise on the RR command that would be used to restore/maximize RR from the taskbar.
    Edit:RAWPWR, I see that you've posted a few times in the RRMousetrap thread. Are you using a mouse to trigger? If so, are you able to use the mouse to trigger while RR is minimized?
  10. #620
    May 2007
    I'm using JoyconEx with hotkeys. I don't use RRMousetrap. So I guess your problem is different.... almost.
    EDIT: I was going to use the Mousetrap route for only RRVoice with a modified mouse/monetary switch and use my Sony controller with JoyconEx just for navigating around DFX skin, but I never got that far. So I only use the Sony/Joycon.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
