View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 7 of 242 FirstFirst 123456789101112131415161757107 ... LastLast
Results 61 to 70 of 2412
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #61
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by CARLOS_CET View Post
    I grabbed it a while ago when LSX Void 3 was just out. So I don't know where to find it anymore. The delete song consists of a deletecurrent folder some confirm skins. I don't know if it's related but the "Remove Song" button doesn't work for me either. I never use it but was trying it out for my debugging. I don't have the source for the delete.exe so I don't know where it's breaking. Basically what happens is that I press the delete song button that I added, I get a confirm screen, select yes and then I get a Delete Completed but nothing happens. The only way I got it to work is if I add a new album and select delete song before I do anything else. I need this function!!! If anyone can help I would greatly appreciate it. I'm going to continue to dig in.
    Use the command "minus1" - (see skincommands.txt)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  2. #62
    Newbie Scratch's Avatar
    Nov 2009
    North Carolina
    Quote Originally Posted by zenonek View Post
    Thank you
    That is what i did, still not working... only that my path is d:\GarminMobilePc\Que.exe
    Or maybe it has to be in program Files??
    Just check your mapping to Que.exe like you mentioned. I think you have to change it in more than one place in skin.ini
  3. #63
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Quote Originally Posted by treetop777 View Post
    Treetop... thanks for the tip. I'm not really interested in getting the "Remove Song" function to work. I'm trying to get the Delete Song/File function to work. I found the "DELETEFILE" command in the skins command.txt file. When I use that function, I get a confirmation skin but still nothing happens. Can anyone else try this?
    Replace the following in our Audio_playlist.skin file
    Change lines 28 and 29 to
    L,700,124,90,28,#DFX1R#,#DFX1G#,#DFX1B#,17,#DFXFON T#,"=Song","CENTER"
    L,700,98,90,28,#DFX1R#,#DFX1G#,#DFX1B#,16,#DFXFONT #,"=Delete","CENTER"
    Change line 53 to
    B1,695,83,100,79,"DELETEFILE",
    You should now have a Delete Song button in your playlist window. Any help is appreciated.
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  4. #64
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The "DELETEFILE" cmd will only work on a screen that has a DL (directory list) in it. Otherwise you have to find some other way of deleting it.
    Ok, I threw this together real quick... but only execute it from your popup confirm screen. As it will STOP current playback, waits 1 sec, deletes file, advances to the next song and begins playback, and reloads the playlist to reflect the adj to the listing.
    Drop in skin folder
    Cmd from your popup Yes btn would be like "ESC||RUNQ;$SKINPATH$DeleteSong.exe"
    U run it, it WILL delete current song file!! You have been warned...
    Just remove the ".txt" from the end
    Added source code, is in vb6
    Attached Files Attached Files
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #65
    Sep 2009
    I downloaded the new version today and I'm back to
    RR taking forever to load...
  6. #66
    Aug 2004
    NH
    Drop in skin folder
    Thanks! What makes a screen a Directory List screen? I used to use the Audio_Playlist.skin screen in DFX4. Isn't that considered a screen with a DL? Or the Audio_Browser screen? I used the delete command you sent and it did what you said it would but I found that I lost my list of songs in my playlist.
    **Edit*** I got it working now and I don't lose my playlist. Is there any way to get the playlist to refresh so that it shows that the song that was just deleted, is not there anymore? ***
    I can try and get the delete_current program to work but I guess I need to understand what screens have the directory list. Also, is there a reason that the Remove Song doesn't work? I don't use it but was wondering if that pointed to anything that might be wrong or related to my issue?
    Car PC Progress
  7. #67
    Sep 2006
    War-Town, GA.
    MGD also had something like that in his skins, it used a winamp feature that would send the file to a "delete" folder. There is no turning back with El C's delete script, it deletes the file completely - caput! Finito! I wonder why you would want to do that??
    Minus1 removes the song from the playlist and the next song plays (flawless). If you don't want that song to show-up again, why not just save the playlist?
    Just saying..
    M2-ATX Power Supply
    Windows XP SP3
  8. #68
    Feb 2006
    [QUOTE=silvi4000;1415500]You guys should really consider replacing RRCam with MiniCam:
    Hi Silvi4000,
    After reading your recommendation on Minicam, I've decided to go for it.
    I have couples of questions
    1. Could you share how you embed it to your skin, and some screenshots?
    2. What is your resolution setting, and what it the FPS in day and night
    3. What codec you use for the recording? (Mainly Video)
    Thanks in advance!
    br,
    /Vinchan
  9. #69
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Just a note, the skin IS using MiniCam. There is just a custom script that is bombing out, and we are looking into it. It will probably be a patch to install at a later time. When the script is corrected, you will be able to see up to 4 cams at once, at the same time. You will then be able to choose individual cams with the buttons on the right to make them larger.
    I will be putting, yet another, update fill installer in the store in a couple of hours from this post time. The mini cam will work somewhat without bombing out, but is not fully functional.
    Also, the deleting file option will be in this release as well. In the player screen there is a "Remove Song" button. Press and HOLD that button for 1 second to delete the currently playing file. You will get a warning that it will PERMANENTLY delete the file, and you have to press and hold yes to do so.
    My Fiero Build Thread
  10. #70
    Feb 2010
    HD Radio
    Just installed 5.0.1 and i have a couple of problems
    1. with HDradio. Scan mode is not working, i press it and nothing. If i use direct tune it works , i can save presets etc. , but scan is dead. I use Directed HD radio with mitch's MJS gadgets cable. I also tested with 5.0.0 version of the skin and it does exactly the same
    2. I can't start Maintenance plugin, i tried registering it again manual and it says that it is registered but rr debug says it's not. any ideas? I tried clean install of october Riderunner and dfx5 skin (both versions). The only thing that may help you is that i'm from greece, and i use greek windows xp pro. as far as i tested everything else works in dfx5 . ( Gauges were stuck and i had to delete the zips file in root of RR to make it work, thanx to help file)
    Great work to all of the team . Way to go!!!
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
