View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 78 of 246 FirstFirst ... 28686970717273747576777879808182838485868788128178 ... LastLast
Results 771 to 780 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #771
    Sep 2006
    Richmond, Tx: USA
    After sometime away from the carputer scene, I finally rebuilt my carputer and installed DFx5 last night and I love the skin but have two issues.
    1) The albumart on the player screen looks VERY bad. It is very pixelated as if a very small picture is blown up. Same albumart looks perfect in DFX4.
    2) When I starts after hibernation or system restart, the "PLAY" button does not show up and the playlist is empty as well (i have it correctly set up in RR Config) but if I press skip or rewind, the list starts showing up.
    Any suggestion?
  2. #772
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by treetop777 View Post
    I noticed there's a difference now that the commands are located in skin.ini as opposed to exectbl.ini - they are not preceded nor end with quotations. I know that having the correct window name at the end of the command is key but i'm confused how to make it work now that the command is in skin.ini?? I've used:
    Sorry, I totally missed this question till now.
    In the next release there is a specific skin now for iGo. This is the command I am using to run it:
    LOAD;GPS_iGo.skin||Run;C:\Program Files\IGOPC8.0.0\igo80_pc.exe;iGO 8 - PNA
    When you say it is not embedding, I am sure that has to do with it having the correct window name to embed. iGO 8 - PNA is the name of the window for the version I used to test with.
    My Fiero Build Thread
  3. #773
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Will be seeing anything of Blue's GPS Events in this release?
  4. #774
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Just noticed the command is in many places? No wonder it ain't working! Guess i'm going to have to make all these match and see..
    Code:
    MainMenuExec_04=LOAD;GPS_iGo.skin||RunQ;C:\iGo8OEM\igo_pc.exe;iGO8 - PNA
    MainMenuLabl_04=iGo
    MainMenuExec_06=LOAD;GPS_iGo.skin||Run;C:\Program Files\IGO8OEM\iGO-MySize.exe |-width=800 -height=470;iGO8 - PNA
    MainMenuLabl_06=iGo
    MenuExec_73=LOAD;GPS_iGo.skin||Run;C:\IGO8OEM\igo_pc.exe;iGO8
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  5. #775
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    I just checked here, that seems to be your doing It is in only one place in the installer skin.ini.
  6. #776
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by JohnWPB View Post
    Ok, It must be me. I been hacking-away pretty heavy anyway. Time to re-install.
    Thanks.
    OLD SYSTEM (DEAD)
    M2-ATX Power Supply
    Windows XP SP3
  7. #777
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Question
    John and Blue, this is what shows up at top now after new March RR update. What is rrpl? (rr playlist?) How to fix? I'm going to delete music data base and rescan to see if it fixes it. Lucky this is on test lappy (xp pro) before updating to carpc.
    EDIT: No go. This happens after restart of RR/DFX. Maybe it's a fix in new patch? Thanks buds.
  8. #778
    Nov 2009
    everytime i see a new post i get all crazy thining its the new release. I cant wait i am going nuts lol
  9. #779
    May 2007
    Thumbs up
    Fixed! This is not DFX or RR. Just Winamp needed to be updated. I deleted Winamp v5.13 and reinstalled v5.601 pro and now everything is back to nORmaL again! I also added the .m3u8 to the extension list in RRConfig. Just in case. And I also made sure that I deleted my RRMediaDB.db and did a rescan. I guess v5.13 didn't support .m3u8? Also I noticed the music doesn't resume @ startup until the greeting is done speaking. Excellent! Thanx for this update Mitch.
  10. #780
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, the 5.13 did not support unicode anything including PL's (*.m3u8). And is not longer the recommended version, current is, until we find one that has issues..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
