View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 79 of 246 FirstFirst ... 29697071727374757677787980818283848586878889129179 ... LastLast
Results 781 to 790 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #781
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Now thats how to improve DFX lol...
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  2. #782
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    You likey? I was going to use my black SG but it would look to dark for a theme. So I used another axe, this PRS instead. I like the blue combo.
  3. #783
    Feb 2005
    Cali
    Set Music Button to default to the Music Browser screen
    Hey all,
    I'd like to set the Music Button to go to the Browser initially, instead of have to choose it from the Music screen.
    I set it up in DFX4.0 by using the DFX Button Editor and editing the exectbl.ini.
    I am not sure if this is the correct way in DFX5.0 - Can anyone comment and provide some direction?
    Thanks in advance
  4. #784
    Registered User
    Aug 2010
    Plugins not loaded on Windows Startup
    New here, sorry if this was not posted properly.
    I have windows 7 64 bit and running the current version of rr with dfx5.0.3. My problem is I have RR in the Startup of Windows and when I turn on the PC the Skin loads fine, but no other plugins are loaded/listed other than dfx5. If I close down and relaunch I'm good to go, but that defeats the purpose.
    Any suggestions?
  5. #785
    Oct 2004
    St. Louis area
    I have the same Windows as you and I simply have all of my programs in the Startup of Windows. Luckily, RR is the last to load so all I have to do is tap the corresponding RR button (instead of minimizing the programs to get to RR) and then RR formats it to fit once I do that.
    Toyota Tacoma Install
    BMW 325Ci Install - Old
    ZOTAC H55-ITX, Intel i3 & 320 Series SSD
    7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
    Win 7, RR, Garmin, DashCmd
    Morel Elate 9 3way & IDQ10 ported (active 4-way),
    JL Audio HD Amps, Audison BitOne.1
  6. #786
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by gunmetalblue View Post
    Any suggestions?
    Attach a debug log, but other than that, it shouldn't not load the other 'global' plugins. Sounds odd..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  7. #787
    Registered User
    Aug 2010
    I ended up removing the copied exe and added a shortcut to the rr exe, which resolved the problem.
    On a side note I was unable to locate a rr debug file. The app is configured with debug enabled. Where is that file located? The Logs directory located in the Ride Runner folder only has a log for the mobilephone.net plugin I recently installed.
    Historically, has the netradio feature been able to display the songs. I see a song history button, but the system doesn't display songs or store them at least visually in the skin. thanks again!
  8. #788
    Jan 2010
    Hi,
    Can anyone tell me how easy/hard it would be to make a button to delete a song completely from the hard disk please? I am about to go away on Sunday and will be covering approx 3000 miles, so would love to "clean" up my music collection as I go without reverting to CF 3.1 :-(
    Cheers
  9. #789
    Nov 2009
    Quote Originally Posted by mbc0 View Post
    Hi,
    Cheers
    http://www.mp3car.com/rr-released-sk...4-11-a-29.html
  10. #790
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Hi,
    Cheers
    I've seen your taste in music, may I recommend 'Format C:'
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
