There is just one small problem with this....dfx has NO hidden playlists on any screen. And that "MINUS1" cmd works only when you have a PL on the screen from which it is called from....
Printable View
Can anyone else verify that there is an issue on the vehicle maintenance screen? When you first go to the screen the first maintenance line is garbled, and the red/yellow/green indicators are missing. I compared to the Carwings maintenance screen I was using before, and determined that this line solved my problem:
SC,372,83,283,303,,,,,,,,,,,,,,20,"Arial"
It's part of my filtering process of music. Sometimes I put songs in the car that I end up not liking. So I would like to delete it. Although the previous deletecurrent function I was using would put the file into the recycle bin just in case I made a mistake.
Thanks John!! Is there any reason that the delete couldn't place the file in the recycle bin rather then permanently deleting it? I actually tried holding down the Remove Song button in the first release of DFX5. Not sure what maybe me think of doing that? Was that a feature of a previous release?
That screen should be correct, I'll dbl chk it b4 this next rerelease
That's a pretty nifty little keyboard. I am happy with the DFX OSK, but often need to enter things into text boxes, like Google, where a virtual OSK is needed. I have used CNS V-Key for years, but it is not resizable or moveable. Two questions on this. (1) What does checking auto-click do? (Couldn't find on the website) and (2) how do you load the keyboard?
Ok, now I have lost the mute while using voice command, the voice command still works
but it no longer mutes....I am sure it was working at first, but now it is gone :Cry:
Does anyone have the rrvoice mic indicator on right top of internet radio screen turn green and not stay red all the time? Voice control works flawless with netradio but i don't see this ever change. Other screens are fine like Menu 1,2,etc....
its a skin issue , in menu skin you will see inc,topindicators.txt , this is missing from internet radio ,
but
also in internet radio.skin near the bottom is the old rrvoice indicator ,I10,xx,xx,xx,xx," !RRVC_IND"
this needs to be deleted
Nice, hadnt try the cam screen in DFX5 so didnt realize its using MiniCam. First time opening the cam screen it showed my 2 cams before giving the error. Now it only shows 1 before failing. MiniCam\Cam.au3 seems to be the problem
Once the script is fixed it would be only a matter of defining different screens for single, double and multi cam setup
BTW, in NetRadio the button for ROCK plays some ladyGAGA/hiphop/happypop music :smash:
@ vinchan
im using ffdshow encoder and the cam resolution at 720x576 30fps
