View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 8 of 242 FirstFirst 12345678910111213141516171858108 ... LastLast
Results 71 to 80 of 2412
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #71
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by treetop777 View Post
    MGD also had something like that in his skins, it used a winamp feature that would send the file to a "delete" folder. There is no turning back with El C's delete script, it deletes the file completely - caput! Finito! I wonder why you would want to do that??
    Minus1 removes the song from the playlist and the next song plays (flawless). If you don't want that song to show-up again, why not just save the playlist?
    Just saying..
    There is just one small problem with this....dfx has NO hidden playlists on any screen. And that "MINUS1" cmd works only when you have a PL on the screen from which it is called from....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #72
    Jul 2006
    Can anyone else verify that there is an issue on the vehicle maintenance screen? When you first go to the screen the first maintenance line is garbled, and the red/yellow/green indicators are missing. I compared to the Carwings maintenance screen I was using before, and determined that this line solved my problem:
    SC,372,83,283,303,,,,,,,,,,,,,,20,"Arial"
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
  3. #73
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Just saying..
    It's part of my filtering process of music. Sometimes I put songs in the car that I end up not liking. So I would like to delete it. Although the previous deletecurrent function I was using would put the file into the recycle bin just in case I made a mistake.
    Quote Originally Posted by JohnWPB View Post
    Also, the deleting file option will be in this release as well. In the player screen there is a "Remove Song" button. Press and HOLD that button for 1 second to delete the currently playing file. You will get a warning that it will PERMANENTLY delete the file, and you have to press and hold yes to do so.
    Thanks John!! Is there any reason that the delete couldn't place the file in the recycle bin rather then permanently deleting it? I actually tried holding down the Remove Song button in the first release of DFX5. Not sure what maybe me think of doing that? Was that a feature of a previous release?
    Car PC Progress
    (>>>>>>>>>>>>---) 90%
    "Don't speak about it, be about it"
  4. #74
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That screen should be correct, I'll dbl chk it b4 this next rerelease
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #75
    Jun 2002
    Virginia
    Quote Originally Posted by jarepa View Post
    Actually I got around it replacing DFX5 OSK with a translucent adjustable keyboard that someone posted while back in the forums. Just changed the action on the OSK button to load the keyboard.
    The name is Free Virtual Keyboard and I believe you can get it at
    http://www.freevirtualkeyboard.com
    That's a pretty nifty little keyboard. I am happy with the DFX OSK, but often need to enter things into text boxes, like Google, where a virtual OSK is needed. I have used CNS V-Key for years, but it is not resizable or moveable. Two questions on this. (1) What does checking auto-click do? (Couldn't find on the website) and (2) how do you load the keyboard?
  6. #76
    Sep 2009
    Ok, now I have lost the mute while using voice command, the voice command still works
    but it no longer mutes....I am sure it was working at first, but now it is gone
  7. #77
    Jun 2002
    Virginia
    Quote Originally Posted by locs4dayz View Post
    I have a few programs that I would like to be able to launch from the extra apps menu. How do I do the so that they will work? I also have games that I would like to be able to launch that are not automatically listed on the games menu screen. Would be great if I could add them to the games menu list and launch them from there. How do I accomplish these tasks? Right now I have to exit or minimize RR in order to launch them as of now.
    You might want to read through the RR FAQs.
  8. #78
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Does anyone have the rrvoice mic indicator on right top of internet radio screen turn green and not stay red all the time? Voice control works flawless with netradio but i don't see this ever change. Other screens are fine like Menu 1,2,etc....
  9. #79
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    its a skin issue , in menu skin you will see inc,topindicators.txt , this is missing from internet radio ,
    but
    also in internet radio.skin near the bottom is the old rrvoice indicator ,I10,xx,xx,xx,xx," !RRVC_IND"
    this needs to be deleted
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  10. #80
    Oct 2007
    Just a note, the skin IS using MiniCam. There is just a custom script that is bombing out, and we are looking into it. It will probably be a patch to install at a later time. When the script is corrected, you will be able to see up to 4 cams at once, at the same time. You will then be able to choose individual cams with the buttons on the right to make them larger.
    Nice, hadnt try the cam screen in DFX5 so didnt realize its using MiniCam. First time opening the cam screen it showed my 2 cams before giving the error. Now it only shows 1 before failing. MiniCam\Cam.au3 seems to be the problem
    Once the script is fixed it would be only a matter of defining different screens for single, double and multi cam setup
    BTW, in NetRadio the button for ROCK plays some ladyGAGA/hiphop/happypop music
    @ vinchan
    im using ffdshow encoder and the cam resolution at 720x576 30fps
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
