View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 80 of 242 FirstFirst ... 30707172737475767778798081828384858687888990130180 ... LastLast
Results 791 to 800 of 2412
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #791
    Jan 2010
    Ok, I have typed format c: and now I cannot even run Ride Runner any more? I have tried rebooting and it says "Insert System Disk" what does that mean??? where have I gone wrong??? ;-)
    Wicked! I have got it to delete the song permanently & RR auto moves to the next track....just for the ultimate tidyness, is there a command I can enter that will also remove it from the database as it still thinks the song is there?
    MANY MANY Thanks for this, it has been something I have wanted for a long time :=)
  2. #792
    May 2008
    Bend, OR
    haha You almost got it right format c: /q echo y
  3. #793
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by mbc0 View Post
    No, but I'll consider it a good suggestion to implement in the RRMedia v2.0 when I work on it some more.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #794
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    RRVoice Problem perhaps
    I am using RR latest version also applies to the prevoius version. Skin is DFX5 lastest version. On startup I hear pops and clicks but no greetings. In the background is a popup labeled DFXSpeak activeX error '429' cannot create object. Applications outside of RR do vocalize okay. I originally posted on this Nov. 2010.
    Any ideas on how to correct this?
  5. #795
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Let's try some info: OS&(full/stripped?) and any other info that you can think might help narrow down your issue.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  6. #796
    Dec 2008
    Quote Originally Posted by themlruts View Post
    Has RRvoice been fixed to work on Win7? I am rebuiling my car pc and would like to run 7 but i know RRvoice include had problems with WIN7
    THanks
    Mike
    no word that i know of. dfx5 has a patch coming, but john has been taking time off deservedly. im not sure how far along jebus is with getting rrvoice to work in win7 either, but i assume he is also taking time off because last i heard it wouldnt be that hard to get working.
    i too am waiting for this though. i havent used xp in years and it still bothers me i have to. the little frustrations ive always had with that os are still there....
  7. #797
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Unhappy
    I started adding songs to virtual cd changer (RRMedia) and after adding about 10 songs to one of the virtual cds I get this error and can't press any of the buttons, it just freezes until I tap menu button to exit music screen. Thanks.....
  8. #798
    May 2007
    OK this might have to do with a plug I have. I don't think this has to do with RRMedia at all. Will test to make sure........
  9. #799
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Assuming that by "can't press any of the buttons" your referring to anything having to do with the RRMedia, as I would assume that message is from the main RRMedia, and when that crashed, you won't get any response as that is the "work horse" of the plugin. If you try doing same with the same set of songs on say another disk, does it crash same song/spot? Looking for the issue that you can repeat, and then its much easier to look for whats causing the error.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #800
    May 2007
    Blue, thanks for the quick response. I thought this error was caused by another plug, that uses GPS and because I didn't have my puck hooked up with iGuidance4. So if I'm reading you right, this might not be the case then? Being this error popped up on the main RRMedia screen? This never happened before I updated RR to new march version, and updated WinampPro from 5.13 to 5.601. I wanted to stay current with changes that Mitch makes with RR's updates and he uses Winamp 5.601, so it was only natural to update Winamp to latest version. Do I have to add .m3u8 ext. to the list of the music section in RRConfig? I added this on another PC, I don't know if this helped or not but, I didn't get that error and also did not have iGuidance installed either. That's why I thought it was another plug. I think I'll add it the list and delete RRMediaDB and rescan to see if this fixes problem. This is the same songs/music collection that is on both machines. Tnx.
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
