What this is coming down to is the
skins Exectbl.ini file, any time the skin is executing a cmd that is in that file, its not being translated like it supposed be. In both of the dfx logs you should see lots of lines that look like "x/xx/xxxx x:xx:xx xx: EXECTBL Translation: xxxxx -> xxxxxxxx....". This showing both the original cmd and the cmd(s) that its being translated to, and yours is not being translated. First, check that the file is there, then make sure that it looks ok when you open it. If it don't look right, delete it, and use a copy of the "Exectbl(orig).ini" file to set it back to its original installed state.
OT, What audio are you using, as I see the debug logs don't show any line info from the mixer?
