View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 86 of 246 FirstFirst ... 36767778798081828384858687888990919293949596136186 ... LastLast
Results 851 to 860 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #851
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    As far as RRVoice, check and make sure that its debug mode is off, as that will slow down RR really bad(RRVoice.ini). That error has nothing to do with RRVC, speach sdk or .net 4.0. When are you getting that error?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #852
    Jul 2010
    Quote Originally Posted by trader007 View Post
    anyone know what i should do with this error?
    ive been getting hangups on startup of RR, and even during use. i think my next step is to reinstall RRvoice, maybe even dfx
    i have already reinstalled speach sdk and .net 4.0
    I had the same error as you from the first time I install RR and DFX 5. However, I thought the reason I get the error due to I used foobar plugin and ASIO output. I think there is some conflict between these plugin. I get the error and have to restart RR. Right now, I still got that error sometime. Don't know why I got it.
  3. #853
    Dec 2008
    i get it when i start up RR. it causes the frontend to hang for minutes while on the "starting mixer and speech" part....
  4. #854
    Nov 2009
    I am trying to get Sygic Fleet running in DFX. Here is the button code. Also it launches but doesnt stretch to fit rr and does really embed it is just floating there
    Load;GPS_Sygic.skin;Sygic DRIVE;C:\Program Files\SygicDrive\Drive\WindowsXP\Drive.exe;Sygic FLEET||ACTIVATE;Sygic FLEET
  5. #855
    Nov 2004
    St Louis
    Quote Originally Posted by yd82 View Post
    That error is from RRmedia plugin. Take that plugin out of the RR plugin Folder and it goes away.
  6. #856
    Dec 2008
    is it straightforward to reinstall RRmedia? because ive always had intermittent problems with that plugin
  7. #857
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Feel free to post issues you have/had in the rrmedia thread when I begin working on v2.0, hopefully soon... That DFXSpeak is not related to rrmedia either, not sure where gizmo is getting that idea from?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #858
    Dec 2008
    i wish it were though. i would like dfxspeak be able to speak to the frontend so it (the music browser) can jump to the song you just commanded by voice. is it feasible to do so?
    pc worked great today though. i jumped in the car, dfx gave no pauses, the internet automatically and seamlessly switched from my house network to my cellular one as i left the driveway and the streaming radio never skipped a beat. now if i can just get this to happen 99 times out of 100 my carpc will be finished
  9. #859
    Nov 2009
    Quote Originally Posted by themlruts View Post
    Bump and help with this?
  10. #860
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1. Where have you put the above code?
    2. Have you set the GPS in RRConfig?
    3. Have you tried it with Carwings?
    The only reason for the GPS application to 'Float' is because the Window name is wrong. Now for Sygic Fleet the window name is Sygic Fleet, so that looks correct.
    Therefore is must be where you hve put the window name.
    Normally you have the Window name and Path for your GPS application set in RRConfig and use the GPS command to load the navigation.
    However if you have used Exectbl.ini to translate the GPS command then the above command should be against that.
    If the above is in the correct place, try it without the activate (it should be OK but maybe causing an issue)
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
