View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
94. You may not vote on this poll
  • Yes, I use it as the primary music browser
    73 77.66%
  • No, I use the standard folder browser
    21 22.34%
Page 92 of 242 FirstFirst ... 42828384858687888990919293949596979899100101102142192 ... LastLast
Results 911 to 920 of 2412
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #911
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What, don't like our American Flag? JK!
    For future reference, you might want to at least try searching or reading the last page or two of the thread before asking about a possible bug, as this was just asked about just a few posts up...
    Thanks,
    The DFX Dev Team
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #912
    Newbie cpufix's Avatar
    Apr 2006
    Paraparaumu, New Zealand
    Thanks,
    The DFX Dev Team
    Thank you for the reply, noted.
    Any feed back on HDRadio I noted this was first addressed to the forum back in Oct 2010 but no replies ?
  3. #913
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by cpufix View Post
    Hi
    Excellent skin and RR is rather refreshing after CF.
    With HDradio, Directed on windows XP pro, I have found that the following buttons do not appear to function :
    AUTO STORE
    SCAN MODE
    NEXT STREAM
    SUB 1 to SUB 3
    When I use the REBORN Skin these buttons in particular AUTO STORE and SCAN MODE do work on the same computer hardware.
    The main button I'm after is AUTO STORE at this stage.
    Ok, I just looked at the code, and yes there were errors on those buttons that were not caught in the beta testing. Attached is the skin with the buttons fixed.
    The SUB 1,2 & 3 are confirmed to be working by BlueZX3 in his car. Keep in mind that the SUB channels will only work if the station is in HD, and then, only if there are sub channels even available.
    (Rename and drop the .txt off of the file name)
    Attached Files Attached Files
    My Fiero Build Thread
  4. #914
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Thanks for the updated HDRadio skin!
    Got a question about day/night theme switching (yes, I did implement the patch). If I leave it set to use GPS settings (the top option in the skin's setting page for day/night switching) then it works, but just not as early in the evening as I'd like. But if I switch it to manual (the bottom setting) and put in times, it never switches for me.
    Does the day/night switching operate independently of RR's day/night skin and gamma settings? How should the RR settings be set to if we're using the DFX5 changer? Ideally I'd like to use auto gamma too to darken the screen at night, but it also seems to not be working, although it did at one point, so I think I have some sort of interaction going on here.
    Yes, my clock is correct and updated regularly.
    Thanks!
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  5. #915
    Apr 2006
    Quote Originally Posted by JohnWPB View Post
    Excellent many thanks for prompt resolution.
    OK Sub's won't work as we don't have HD in New Zealand.
  6. #916
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by Zogg View Post
    If I switch it to manual (the bottom setting) and put in times, it never switches for me........Yes, my clock is correct and updated regularly.
    Thanks!
    Hmmm the only thing I can think of is maybe you have it set to 24 hour format? I use the time switching on my desktop here for testing, and it does switch by the times that I have set.
  7. #917
    Apr 2005
    Plano, TX
    That's not it, but I'll keep playing with it and try to narrow it down.
  8. #918
    Sep 2010
    UK
    Question DFX and Gauges
    Morning,
    I'm running the latest DFX along with the latest RR. and I'm having some trouble with the GPS.
    I'm using destinator 9 for my mapping and this works 100% but as soon as I click in the gauges button it hangs RR/DFX but windows and winamp still respond. I have also tried some software called xport which take my GPS port and replicates it to other ports so both the DFX gauges and Destinator can use the signal just in case this caused the problem.
    Also I have just rebuilt the OS and re-installed all software and the same thing still happens....
    Your help would be most useful... and I'm sure worth a donation!
  9. #919
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    First thing that comes to mind would be possibly the zips.dat file. I see that your location is the UK and if you did a default full skin install, it would install this US only file, which usually causes RR to hang when any screen uses the "LOCATE" command. Look in either RR's folder for that file or in the RideRunner\Config in your documents folder and delete it if found.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #920
    May 2008
    San Jose, CA USA
    "RR Media error" No media database found in DFX 4.0
    Everytime I open Digital FX 4.0 I keep getting "RR Media error" No media database found
    I have RR media installed. Also set the path in Ride Runner config.
    Can anyone help me with this?
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 12-21-2010, 10:58 AM
  2. openMobile 0.6 Released To Testers
    By justchat_1 in forum OpenMobile
    Last Post: 06-26-2010, 01:11 PM
  3. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 10:22 AM
  4. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 12:26 AM
