View Poll Results: While Using the DFX skin, do you use the RRMedia database for your music?
Voters
98. You may not vote on this poll
  • Yes, I use it as the primary music browser
    76 77.55%
  • No, I use the standard folder browser
    22 22.45%
Page 96 of 246 FirstFirst ... 468687888990919293949596979899100101102103104105106146196 ... LastLast
Results 951 to 960 of 2459
Thread: DFX 5.1.2 Released [ Updated 04-02-12 ]
  1. #951
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by JohnWPB View Post
    My first thought was that is impossible. A monitor shows what it is told to really.... Having Medal of Honor work on one monitor, and Brothers In Arms not, would cause ALL sorts of problems in the PC world.
    THEN.....
    I followed you link to the monitor and see that it is a USB monitor. That explains it! There just is not enough bandwidth in a USB cable for perfect video. They are great for many applications, but can have a lot of lag and skipped frames. The drivers probably are drawing the iList, as you said you saw it for a second, then disappears, but then not updating the list and redrawing it.
    It's almost the way video over a remote desktop connection would work. Yea, if you want video and iLists, you need to stick with a VGA. HDMI, DVI monitor for sure.
    ---------- Post added at 04:01 PM ---------- Previous post was at 04:00 PM ----------
    On another note.... and something tells me, there just may be an update to DFX here in the very near future
    Exactly. I knew when I bought it the USB would have limitations, but I didn't plan on playing MOA on it! I figured it could at least handle Ilist and RR. Wrong.. It's not a good idea for a primary monitor even with light application. For a secondary headrest maybe. I Shipped it back and bought another lilli.
  2. #952
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Thumbs up DFX 5.1 Released!
    Ok, the DFX 5.1 Patch is in the App Store HERE.
    *** Note: Unless you want to be a beta tester, I recommend waiting till the next patch is out within the week taking care of some bugs and issues ***
    ** You MUST rename it from .zip to .exe and then run it ***
    This will install over your current DFX install, keeping your settings as far as colors, menu button locations, logo's and other customizations that you have made. All files that are replaced by the update patch, will be backed up.
    If you have purchased the splash screen patch, this will not be effected with the update. The new version of the registered DFX.dll will be used.
    The Full DFX 5.1 installer will be in the Auto App Mart shortly.
    My Fiero Build Thread
  3. #953
    Nov 2007
    PA
    SWEEEEET!
    Thanks a lot for the hard work guys!
    ATTN: Downloaded. Says archive is corrupt and cannot be opened
  4. #954
    May 2011
    The download works fine. As he said YOU MUST RENAME THE FILE FROM .ZIP to .EXE.
    Thanks for the update! Looking forward to seeing if it straightens out a couple of things for me.
  5. #955
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Thanks! Looking forward to the full installer.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
  6. #956
    May 2011
    1.) Wallpaper Changing - Check!
    2.) Autoit error on Cam Screen - Check! BUT cam screens are not being killed on RR exit. I'd also assume that they are not killed when leaving the Cam Screen Skin.
    3.) WiFi Skin tries to load wifi_on and wifi_off.png's which are apparently no longer valid with WiFiman .NET 2.0. If the png's are added to the DFX folder, the skin loads but also has Carwings button backgrounds. This doesn't really matter much because Wifiman won't work on my system anyway at this point. It hangs the system on startup of RR. When I can get around it, it can't find my wireless adapter. Not your issue.
    4.) I may be missing something operationally (user error), but when using "Valet" I'm not seeing a way to unlock the system. Edit: Seems the "hidden" Hotspot for unlocking is missing.
    5.) Not related to this update but I've tried using the DFX Button Editor to eliminate some unused stuff and re-arrange the menu buttons to my liking. After making changes with the button editor, saving and exiting, relaunch of RR shows no changes to my skins.
    6.) Help Button in Menu 2 doesn't display help.
    Thanks for the update.
    7.) No top quicklaunch bar on a few screens. (tough when using voice)
  7. #957
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Driven01 View Post
    Yes, I experienced the same problem. After messing with it quite a bit I figured out how to make it work. When setting up a new button, do not save a button image at first. Instead, just fill in the label field and the RR Command field and then hit done and save and exit. This will save the label and command. Then if you want to add a button image reopen the button editor and add an image to the button you just created. For some reason, it does not save your changes if you add an image at the same time you create the button. Your new button will be added to the pop-up list if you follow this procedure.
  8. #958
    May 2011
    I'd recommend folks don't try the Valet (system lockout) until things are figured out. IF you do, you will be locked out of RR even if you kill it with Task Manager. There is a way out though. Check the DFX Help file (included in today's release) in the "How do I" section under Lock/Unlock the system. Go to the .ini mentioned and change the line Relock=True to Relock=False. This will allow you to use RR as normal until the lockout thing has been worked out.
    ---------- Post added at 09:08 AM ---------- Previous post was at 09:06 AM ----------
    @kbreeden -Thanks for the tip!
  9. #959
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Thumbs up
    No problems that I can see, I only had to put back all my logos that were in the Logos file, but no biggie all good now.
    John, I notice a lot of skins for RR including yours don't have a logo for the Firebird muscle? Well,........... here is a bunch of ones that I made with photoshop if anyone wants to use. I think I have all the colors represented?
    The internet radio is amazing! Great job on this guys!! I'm also adding some stations to add if anyone wants them. Enjoy.
    EDIT: You will find files uploaded on #961
  10. #960
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Voice and phone
    Ok, before I ask this, please don't flame me, I've read everything I could and haven't found the definitive answer(s).
    Thanks for the update. Everything installed smoothly and the patch that I paid for was not affected at all.
    My questions are about voice control and phone. As far as voice, is it built in to DFX 5.1 now or do I need to use RRVoice? I can't for the life of me find that answer or how to set it up. I just went through the entire new DFX 5.1 help and there is nothing in there.
    Bluetooth phone interface. I selected Phoco but it tells me to reinstall the option when installing RideRunner. I've looked at the installation twice and there is no Phoco option anywhere. What is everyone else using for the bluetooth interface with their phone?
    Thanks in advance to all responses.
    "Imagination is more important than knowledge." -AE
  1. Skype Plugin released
    By lambosprit in forum RR Released Plugins
    Last Post: 11-25-2014, 06:26 AM
  2. Teknik v2.0 - RELEASED
    By Valheru in forum RR Skins
    Last Post: 12-04-2007, 11:22 AM
  3. DFx skin + winamp 5.13
    By vicky_obee in forum Road Runner
    Last Post: 12-04-2007, 01:26 AM
