1.) Wallpaper Changing - Check!
2.) Autoit error on Cam Screen - Check! BUT cam screens are not being killed on RR exit. I'd also assume that they are not killed when leaving the Cam Screen Skin.
3.)
WiFi Skin tries to load wifi_on and wifi_off.png's which are apparently no longer valid with WiFiman .NET 2.0. If the png's are added to the DFX folder, the skin loads but also has Carwings button backgrounds. This doesn't really matter much because Wifiman won't work on my system anyway at this point. It hangs the system on startup of RR. When I can get around it, it can't find my wireless adapter. Not your issue.
4.) I may be missing something operationally (user error), but when using "Valet" I'm not seeing a way to unlock the system. Edit: Seems the "hidden" Hotspot for unlocking is missing.
5.) Not related to this update but I've tried using the DFX Button Editor to eliminate some unused stuff and re-arrange the menu buttons to my liking. After making changes with the button editor, saving and exiting, relaunch of RR shows no changes to my
skins.
6.) Help Button in Menu 2 doesn't display help.
Thanks for the update.
7.) No top quicklaunch bar on a few screens. (tough when using voice)
