Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: Uconnect Touch (Updated 7/10/12)
  1. #21
    Mar 2011
    Quote Originally Posted by Dartman_71 View Post
    When you are in player, there is source button which opens menu and you can choose audio, video, dvd etc.
    ...and welcome to the forum
    Thanks. I don't have notice.
    This will be a update to support the IGO 8? I have edit with skin editor to support...
  2. #22
    Jun 2010
    Syd, Australia
    being a jeep driver, I was already sucked in to the uconnect title.great oem look, but i run a 7inch screen in the car, would the icons along the bottom take up too much screen real estate?
    I obviously haven't yet tried in the car but that is my second impression (1st is how sleek this thing looks;-))
    Great job non the less man
  3. #23
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by ZerocoolPT View Post
    I hope this going to pleases you, I had to leave off the top bar because there was no room and iGO refuses to shrink.
    Both iGO 8 and iGO 8.3.x are supported in next UCT version.
  4. #24
    Feb 2009
    Finland
    Quote Originally Posted by mos33y View Post
    I also have 7" screen and in my mind bottom buttons/icons are perfect size and easy to hit. Naturally it's matter of taste, others want huge buttons and others want so small that you need touch pen to operate them.
    Originally UCT runs is 8.4" screen in Chrysler and Dodge so there is more space, I had to squeeze bottom icons little to get more space other stuff but I think skin is quite balanced now.
    Edit: Don't let screenshots fool you, icons are much smaller when running in 7" wide screen with 800x600 resolution.
  5. #25
    Jun 2010
    Syd, Australia
    Hi Dartman,
    1. Thanks for explaining. I just looks at the op and it looked to be made of for 4:3 format.
    2. I go 8.3 support is ALWAYS appreciated ;-)
    3. I can see on top right hand corne rof your screen you have tempin and tempout. where is the data for this coming from? Are you using the temper usb thermometer?
  6. #26
    Feb 2009
    Finland
    Hi Dartman,
    I use 1 wire usb thermometer and Mitch's MJS Gadgets 1-Wire plugin which is not released to public yet, but you could ask plugin from Mitch via pm if you are interested.
    Here is link to shop where you can purchase 1 wire adapter (USB9097) and sensors separately or 2-10 sensors kits.
    Digital sensors are very accurate, unlike analog crap which vary several degrees.
  7. #27
    Feb 2009
    Finland
    Gosh, where all the fun without the tweaking! Now iGO 8.3.x fits perfectly
    ... if someone want modified iGO 8.3.x... let me know.
  8. #28
    Feb 2009
    Finland
    Version 1.01 in first post.
  9. #29
    Jun 2010
    Syd, Australia
    ok cool, so I am assuming you have 2 probes attached? or 2 usb units?
    thanks and oh yeh, great skin ;-) will give v2 a try
  10. #30
    Feb 2009
    Finland
    1 usb unit, 2 probes attached.
  1. Replies: 3
    Last Post: 01-15-2011, 08:25 PM
  2. CF 2.0 - Released
    By midiwall in forum Centrafuse
    Last Post: 08-18-2008, 02:47 PM
  3. LMF 1.1 Released
    By frodobaggins in forum Software & Software Development
    Last Post: 11-04-2004, 12:35 AM
