Page 13 of 30 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 121 to 130 of 298
Thread: Chuck's Skins lots of pics Update 7-16-07
  1. #121
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    My skin has both xm and the standard RR weather plus radar
    The xm weather is just a skin that shows a bunch of presets and channel info for weather, news and sports.
    2001 S10 ZR2
    Chucks Skin - to old
  2. #122
    Constant Bitrate i3igmind's Avatar
    Mar 2005
    audio
    chuck when i click on the Audio bottom button it freezes?
    any suggestion,
    check your pm regarding XM
    HOnda Accord '94
  3. #123
    Low Bitrate 2000Jeep's Avatar
    Mar 2006
    No go there chuck on the gps. any other ideas?
  4. #124
    Mar 2006
    I think i got it chuck. i took everything out but this line.
    /,"STREETGPS","LOAD;EXTERNAL_GPS.skin;Navigation;C:\Program Files\Microsoft Streets and Trips\Streets.exe" - Map File 1"
  5. #125
    Mar 2006
    Quote Originally Posted by Chuck
    You know you can go to the setup menu and add Vol- and Vol+ to the bottom buttons.
    Did not know that and cant figure out how get it to show. Is it in the main RR set up?
  6. #126
    Variable Bitrate 3g Jester's Avatar
    Nov 2005
    sweet thanks man. great skin.
  7. #127
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by 2000Jeep
    From the main menu or tool menu – the first one that comes up when you start RR
    Press the setup button on the left and pick the bottom button you want to use for VOL- then pick the VOL- from the menu. You should see VOL- on the button you selected and save preset 1.
    For this to work you need to pick NAV-USA from my setup menu – note the end of the command line and this ( /,) in front of the command line will just ignore the hole command.
    "STREETGPS","LOAD;EXTERNAL_GPS.skin;Navigation;C: \Program Files\Microsoft Streets and Trips\Streets.exe;Map File 1"
    Should look like this
    2001 S10 ZR2
  8. #128
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by i3igmind
    any suggestion,
    Did you get rid of the moon phase with the window name Form1?
    If so then change
    from
    "AUDIO","LOAD;audio_player.skin;MP3's;;Form1||MOON APP||ACTIVATE;RoadRunner"
    to
    "AUDIO","LOAD;audio_player.skin;MP3's"
    2001 S10 ZR2
  9. #129
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    UPDATE 5-16-06
    You need to Take these two lines out of the ExecTBL.ini file in the RR directory (not the chucks directory) "ONSKINSTART","" and "ONSONGSTART","" and it will show the bottom buttons then
    2001 S10 ZR2
  10. #130
    Mar 2006
    Chuck. All seems good with the skin. I am trying to embed windvd into roadrunner. Media player is just to laggy. I was wondering on how i can do this? Any help from anyone would be great.
    thanks
  1. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 05:47 PM
  2. 1994 ford explorer recessed lilliput lots of pics!
    By xdjxklusivex in forum Fabrication
    Last Post: 01-06-2006, 10:20 PM
  3. Fusion of Zaurus and '00 Accord (lots o' pics)
    By Xumbi in forum Show off your project
    Last Post: 07-12-2005, 11:47 PM
  4. 1997 Chevy Trukputer - DONE! Lot's O' Pics! WHOOO HOOOO!
    By voidunknown in forum Show off your project
    Last Post: 02-07-2005, 10:58 AM
  5. Can't create a post with lots of pics??
    By tbird2340 in forum Mp3car Forum Suggestions/Comments
    Last Post: 09-09-2004, 02:43 PM
