Nice Truck!
Update 6-10-06
Added gauge skin – thx happyg
Now change channel and labels in xm and Sirius presets without switching skins – also added some help
Added more commands in the iguidance skin
Fixed some stuff
With this skin your better off not running an ExecTBL.ini in the RR directory – just rename it
http://mywebpages.comcast.net/charlesrichards/ChucksSKINII.zip
UPDATE 6-12-06
Changed some stuff in the audio browser.
Made the skip to work better for both play list and directory list.
Changed the bottom buttons on hold to work more efficient.
Added hold labels to the bottom buttons that can be turned on and off easily after you get use to them.
Changed both check list to one skin instead of two
And cleaned and fixed up stuff
chuck, pardon my ignorance of your skin's progress, but, is this latest screenshot showing a variation of winamp's "j" aka "goto song" feature?
replicant
Audi A4 (flickr pics)
This is the RR "SKIPTO" Command
"SKIPTO" - This allows you to "jump" to a letter in any list.
Example: "SKIPTO;K" (would go to the first item in the current list starting with K)
Update 6-18-06
Added my automatic player
Not only will it cycle thru the 4 players now but also it will cycle thru my presets in each player.
You can just have one player activated and it will just cycle thru the presets you select.
I intergraded an auto button in all my players to just cycle thru presets and read out runtime on the button. Also if you hold the button it will take you to the settings skin.
The cycle will automatically stop if you go to anther player
I forgot to put the add to rr.ini file – down load at bottom of this first post
I cannot believe how complicated and advanced your skin is. Much props to you Chuck for the constant upgrading and hardwork you've put into this skin.
replicant
Update 6-1-06
Changed some stuff in the automatic player
Took out last screen setting – works by itself now
Added hold and resume
Works with GPS mode in players now
Fixed lockup when you start with no players selected
Down load update.zip file at bottom of post 1
Update 6-21-06
Well I like this automatic player so much I decided to add all my presets.
Added manual mode – set timer to 0
Added next and previous selection – just use next and previous in all my skin at bottom right when automatic is running
Changed some stuff
Fixed a lot of stuff
Update file at bottom of post 1
Update 6-25-06
Automatic player changes
Added a little help scroll
Added indicator in bottom buttons so you know Which player is activated
Changed auto button in all players – white for single player mode red for switch player’s mode
Fixed xm last screen not working right
Update at bottom of post 1
