Update 6-28-06
fixed audio not changing when radio is off
Update at bottom of post 1
Update 6-27-06
Did more stuff with automatic player
Fixed typeo-bug in xm – not showing active xm
Added wait for end of song in audio player part
Changed timer 0 5 10 15 20 30 45
Added countdown for end of song
Added underline indicators to see what’s going on with presets
Update 6-28-06
UPDATE 7-9-06
Added pic viewer with slide show
Multi player stuff
New quick menu
Now with auto mute so you don’t hear all that junk wile the channels and play list are changing.
Wait for end of song now works XM and Sirius too. – thx guino
Faster saves and restore – thx guino
With this skin your better off not running an ExecTBL.ini in the RR directory – just rename it
http://mywebpages.comcast.net/charlesrichards/ChucksSKINII.zip
Hey chuck how do u make your skin center with 800 by 600 its always going somewhere else on the screen
I do not understand what somewhere else on the screen is.
That space at the top is so you can see IG and copilot directions all the time when you hit the Nav-IG button a second time.
Then you can hit the bottom bar to get IG full screen.
Look at post #31
But you can change it in the general.ini file
Update 7-10-06
Had a bug in the ExecTBL.ini file with Sirius – file at bottom of post 1
What I mean is i am using 800 X 600 but when i turn your skin on, you skin is not center. Its half off on the screen and I can still see the desktop. i tried to change your skin in the general.ini to 800X600 but then your skin looked funny
You need to turn Clear Type on and then it should look just as good as 1024x768
Control panel
Display
Appearance
Effects
Use the following method to smooth edges of screen fonts:
Clear Type
Then ok and apply
The setting in the General.ini file
OriginalWidth=1024
OriginalHeight=683
ShowWidth=800
ShowHeight=534
XPosition=0
YPosition=66
if you do not what the space at the top
OriginalWidth=1024
OriginalHeight=683
ShowWidth=800
ShowHeight=600
XPosition=0
YPosition=0
What does it look like?
Try removing these from the ExecTBL.ini From the Road Runner directory – not the from the chucks directory
"ONFILECLICK",""
"ONDIRCLICK",""
"ONPLCLICK",""
"ONDLCLICK",""
"ONPBCLICK",""
"ONPLSELCLICK",""
"ONDLSELCLICK",""
"ONSONGSTART",""
"ONSKINSTART",""
and let me know
