Renaming the file is ok but only the one in the Road Runner directory – not the from the chucks directory
What does it look like?
Did you copy and paste the stuff from the -ADD TO rr.ini- to -rr.ini- file?
UPDATE 8-17-06
Improved auto player
Added winamp library skin
Added some simple touch screen games
Added auto skin return to active player
Added all apps or action skin – second press of tools
Added DVD skin
Added a little help for all apps in setup skin
http://mywebpages.comcast.net/charlesrichards/ChucksSKINII.zip
With this skin your better off not running an ExecTBL.ini in the RR directory – just rename it
1:What out button?
2:add phone=0 to the rr.ini
3:set path in rr.ini to your pic folder –sample >>> picspath=E:\Camera\6-18-99 Zoo
Sounds like you did not copy the new ADD TO rr.ini to the rr.ini file
Do me a favor and zip up your rr.ini and ExecTBL.ini and post here for me
let get past this step first
ok this as changed some how but you need to go to setup as soon as open RR and set the buttons the way you want them and save the prsets.
so try to change button presets and save then quit RR and restart and see if the setting you saved work and let me know.
this what i had in the rr.ini
BUTTONSET=0<<2<<35<<1<<3<<16<<5<<7<<8
BUTTONSET1=0<<2<<35<<1<<3<<16<<5<<7<<8
BUTTONSET2=7<<20<<6<<19<<9<<24<<10<<49<<43
BUTTONSET3=26<<28<<27<<33<<47<<46<<21<<34<<48
