Page 17 of 30 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 298
Thread: Chuck's Skins lots of pics Update 7-16-07
  1. #161
    Constant Bitrate i3igmind's Avatar
    Mar 2005
    Quote Originally Posted by Chuck View Post
    let get past this step first
    ok this as changed some how but you need to go to setup as soon as open RR and set the buttons the way you want them and save the prsets.
    so try to change button presets and save then quit RR and restart and see if the setting you saved work and let me know.
    this what i had in the rr.ini
    BUTTONSET=0<<2<<35<<1<<3<<16<<5<<7<<8
    BUTTONSET1=0<<2<<35<<1<<3<<16<<5<<7<<8
    BUTTONSET2=7<<20<<6<<19<<9<<24<<10<<49<<43
    BUTTONSET3=26<<28<<27<<33<<47<<46<<21<<34<<48
    nope i tryed to change the buttons in the setup and saved them, and when i quit and run RR again it didn't work
    HOnda Accord '94
  2. #162
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I just cannot figure out what is going on with your setup so the only thing I can think of is start over.
    Ok make sure you have at least 7-8-06 version of RR.exe
    Rename your Chucks folder - ChucksOld
    Down load CkucksSKINIIII.zip and unzip and make sure everything is new – just redid it today
    Then open RR and select Chucks Skin then quit RR and restart RR to make sure Chucks skin starts as soon as RR starts.
    Go to setup and try to change button preset 1 and save preset 1 then quit RR and restart and see if the setting you saved work and let me know.
    2001 S10 ZR2
    Chucks Skin - to old
  3. #163
    Mar 2005
    idea
    hey i will do what you told me, but i ve been busy latelly,. listen man i was driving the other day and i thought of an idea and i want to ask you if its doable with your skin:
    on the Audio_Player skin, the slide bar on the right is it possable that when someone hit the down or up arrow , it'll display like a page number, for e.g. on my screen it fits 7 songs every page, so say i iknow there is a song on page "7", then i will scrol down untill i see "7" on the slide bar.??!!!
    HOnda Accord '94
  4. #164
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Not that I can think of right now
    Just use skip to or in my skin its called goto
    Or search – the magnifying glass
    2001 S10 ZR2
  5. #165
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Update 8-31-06
    --------- YOU MUST INSTALL CHUCKSRR FONT AND REINSTAL ALL CHUCKS FOLDER -----------------------
    NEED TO ADD THE -ADD TO RR.INI FILE TO RR.INI FILE
    Added song reminder – just touch bottom left to add song
    All players use the same set of skin.jpg’s now
    All buttons use text graphics instead of graphics on .jpg’s
    Changed main menu – simplified it and add bass and treble back in
    Changed xm and Sirius – now with preset menu
    And the list goes on
    2001 S10 ZR2
  6. #166
    Feb 2006
    OK guys, total Newbi here to RR so bear with me. Here is the problem I'm having. I think I have the skin installed properly, installed the font added the extra to the rr.ini, renamed the ExecTBL.ini. When I launch RR and go to setup I have nothing listed there for buttons just a empty screen. Am I missing something, again I've been using Frodo for some time so my mind is still trying to shift gears and I'm fear I'm confusing myself more that I need to. Thanks in advance for any and all help, LOVE this skin, now if I can only get it to look like yours(Chuck)! Thanks -Peter
  7. #167
    Feb 2006
    Scratch that last post. I figured that one out, now the problem I'm having is well a couple things. When running RR with or without this skin it is very slow. I mean I click on the NAV button and it can take a couple minutes to goto that screen and get IG running. However if I launch IG from the dsesktop it is seconds if that to have it up and running. Any thoughts? Also when running IG in a 800x600 sized skin, it seems to cut the left of the IG screen off as well as looks wierd when full screen from behind. I have been playing with ini's but I think I might be making it worse. Any help there? Thanks in advance!
  8. #168
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Yes
    1 update RR to the beta.
    2 wait a day or two I am coming out with a new version of this skin with lots of new stuff and a fix for IG.
    Added gas.
    Change top display color on the fly.
    Audio preset buttons that remembers track numbers in each preset.
    Smoother skin switches.
    Added a trip meter.
    All indicators and buttons use text graphics for easer mods.
    And the list goes on.
    I will try to get this out today for you.
    thx
    2001 S10 ZR2
  9. #169
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Update 9-16-06
    Need to do a complete install
    Need to reinstall font
    Need to add my rr.ini to rr.ini
    Added a power button to stops whatever player is running and turns off the display also cuts cpu almost down to nothing
    Hit any button and display comes back on and the music playing in whatever player was going
    Added gas. – hit any gas station and the address will to go track name in gas and gps skin
    Changed the moon phase to a big clock – top left
    Change top display color on the fly. – three colors
    Added a trip meter. – thanks to festy
    All indicators and buttons use text graphics for easier mods. – thanks guino
    Moved control and MP3 Preset folders in chucks folder
    Chopped this thing way down and now there is only 33 skin.jpg to edit the whole skin. - 14 of those are menus
    I changed just about everything
    http://mywebpages.comcast.net/charle...hucksSKINV.zip
    2001 S10 ZR2
  10. #170
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    yo chuck your pm box is full
    beer replenishment fund
    mp3car live search
  1. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 05:47 PM
  2. 1994 ford explorer recessed lilliput lots of pics!
    By xdjxklusivex in forum Fabrication
    Last Post: 01-06-2006, 10:20 PM
  3. Fusion of Zaurus and '00 Accord (lots o' pics)
    By Xumbi in forum Show off your project
    Last Post: 07-12-2005, 11:47 PM
  4. 1997 Chevy Trukputer - DONE! Lot's O' Pics! WHOOO HOOOO!
    By voidunknown in forum Show off your project
    Last Post: 02-07-2005, 10:58 AM
  5. Can't create a post with lots of pics??
    By tbird2340 in forum Mp3car Forum Suggestions/Comments
    Last Post: 09-09-2004, 02:43 PM
