Page 23 of 30 FirstFirst ... 131415161718192021222324252627282930 LastLast
Results 221 to 230 of 298
Thread: Chuck's Skins lots of pics Update 7-16-07
  1. #221
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Just drop these files in the chucks folder and rename without the .txt
    Attached Files Attached Files
    2001 S10 ZR2
    Chucks Skin - to old
  2. #222
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    The next release should be a snap to setup and change buttons, colors, skins and on and on.
    2001 S10 ZR2
  3. #223
    Nov 2004
    St Louis
    Quote Originally Posted by Chuck View Post
    I know I've probably said this before, but THIS SKIN IS AMAZING!!!!!
    Had a chance this weekend to run ChuckX through its paces and at every turn I was saying WOW. Its going to take me weeks to open it up and figure out how some of this works, but after seing the light day skin in the car I'm almost ready to abandon my highly modified Mac-V2-Day shin for this. Gotta wait for Spring to put the top down and see what it looks like in direct sunlight.
    Now for some requests:
    1. Have you (or would you) link the two traffic screens, i.e., if you change the traffic city in the text skin it also changes the city in the traffic maps skin and vice versa (probably ony requires a couple extra commands be added to the exectbl.ini). And then incorporate buttons in each to jump to the other.
    2. I'm still wrestling with whether I want tie also tie in the weather screens to the traffic ones, but (and I know you don't travel outside your region much) it wouldn't take much, i.e., I've already written the code, to expand the weather maps to a tiered system of 18 maps with 6 US maps, 6 regional maps, and 6 local doppler radar screens kinda like the 12-06-05 update.
    This is definately the most full featured RR skin, keep up the good work.
  4. #224
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Thanks GizmoQ
    Lots of changes in the one I am working on now
    Tying the 2 traffic things is no big deal but the weather radar thing would be tuff unless you have fixed cities in RR weather to pick from.
    Ps updated pic above
    2001 S10 ZR2
  5. #225
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    new skin picker
    2001 S10 ZR2
  6. #226
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    UPDATE 2-19-07
    Totally changed all the setup stuff - Will not have to hunt for them.
    Added Traffic Map Plugin--by moahdib.
    Added display memory so it will remember the last display color in each skin.
    Will need to do a full install and clean out old chucks stuff in rr.ini.
    And Lots more.
    http://mysite.verizon.net/charles.ri...ucksSkinXI.zip
    2001 S10 ZR2
  7. #227
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Next update you will be able to change radar maps right from the skin.
    Redid all the autoitís scripts for radar, traffic text and traffic maps/
    No more *.ini files to edit at all in the skin now. All gone
    2001 S10 ZR2
  8. #228
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Radar autoit now
    Code:
    $RR = ObjCreate("RoadRunner.SDK")
    $skinpath=$RR.GetInfo("=$SKINPATH$")
    $RRpath=$RR.GetInfo("=$RRPATH$")
    $MAP1=$RR.GetInfo("=$RADARMAP1$")
    $MAP2=$RR.GetInfo("=$RADARMAP2$")
    $MAP3=$RR.GetInfo("=$RADARMAP3$")
    $MAP4=$RR.GetInfo("=$RADARMAP4$")
    $MAP5=$RR.GetInfo("=$RADARMAP5$")
    $MAP6=$RR.GetInfo("=$RADARMAP6$")
    InetGet(""&$MAP1&"", ""&$skinpath&"Weather1.jpg", 1)
    InetGet(""&$MAP2&"", ""&$skinpath&"Weather2.jpg", 1)
    InetGet(""&$MAP3&"", ""&$skinpath&"Weather3.jpg", 1)
    InetGet(""&$MAP4&"", ""&$skinpath&"Weather4.jpg", 1)
    InetGet(""&$MAP5&"", ""&$skinpath&"Weather5.jpg", 1)
    InetGet(""&$MAP6&"", ""&$skinpath&"Weather6.jpg", 1)
    Run(""&$RRpath&"exec.exe RESETMAPS")
    2001 S10 ZR2
  9. #229
    Nov 2004
    St Louis
    Radar autoit now
    Code:
    O.K. Let's see if I follow this. My skin uses variables in the exectbl.ini that are set in the skin page to select one of 5 autoit programs that output to the "$ww$weather1-6.jpg." Yours sets the variable on the skin page and then runs this one autoit. I have 30 jpgs in my weather subdir and you only have the 6.
    Do you have any time delay with the autoit vs RRCode scripting. With my slow processor and connection, the above would probably bog my system down. What's nice about my way is the recent maps at all levels are immediately available while I wait for the autoit to get current maps and update - makes for quick switching between levels.
    Can't wait to see the RRCode that goes with this.
  10. #230
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Basically this autoit reads the variable I have set in RR and stored in Skin.ini and settable from a radar setup skin.
    RADARMAP1=http://image.weather.com/web/radar/us_dca_closeradar_medium_usen.jpg
    Then downloads the file to the skinpath set in RR
    Then runs a command in RR I have setup to reload all the jpgs on the radar skin.
    And all done without any .ini files or path to set and will only do anything while RR is running.
    Seems just as fast as before – I use a 550mhz pc desktop for this.
    2001 S10 ZR2
  1. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 05:47 PM
  2. 1994 ford explorer recessed lilliput lots of pics!
    By xdjxklusivex in forum Fabrication
    Last Post: 01-06-2006, 10:20 PM
  3. Fusion of Zaurus and '00 Accord (lots o' pics)
    By Xumbi in forum Show off your project
    Last Post: 07-12-2005, 11:47 PM
  4. 1997 Chevy Trukputer - DONE! Lot's O' Pics! WHOOO HOOOO!
    By voidunknown in forum Show off your project
    Last Post: 02-07-2005, 10:58 AM
  5. Can't create a post with lots of pics??
    By tbird2340 in forum Mp3car Forum Suggestions/Comments
    Last Post: 09-09-2004, 02:43 PM
