Page 14 of 51 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 501
Thread: Simplistique Skin Release - download and screenshots
  1. #131
    Jul 2005
    Wales, UK
    @TheFaze
    I'm not sure how to do this. I think the visu might be audioplayer specific. Nice idea tho.
    LLOYDY
  2. #132
    Low Bitrate wishbone's Avatar
    Feb 2006
    Quote Originally Posted by raymondrza
    Thanks for the reply!
    Oddly enough, option 1 still produces a docked toolbar (for me). Iguidance as a standalone app will display fullscreen sans the toolbar (with the floater). If in RR I select the maximize button on the tool bar, RR still keeps it embeded the same way with the docked toolbar. I also added the "/ F" to the .exe line in both the skin and the RR.ini to issue the Fullscreen command, but to no avail. Docked toolbar sux, I need to get rid of it.....
    When I get home from work, I will look into option 3.
    Thanks,
    Mark
    I know if you "grab" and drag the toolbar off the docked position it will float.. then you can close it. However every time you reboot (maybe even restart ig) it will reappear. =T
  3. #133
    Apr 2006
    Question
    Am I incorrectly claiming to have embeded Iguidance, or am I just confusing the floating toolbar term? Either way, I think my problem is better described with the attachment.... Thanks for any help
    Mark
    The dude abides.
  4. #134
    Feb 2006
    ohhh, hmm that is strange. It looks like maybe your RR doesn't know the window name so it's putting in the window name graphics as well. Seems strange. The only time I've seen that happen is when the name of the window wasn't specified correctly in one of the config files.
  5. #135
    Apr 2006
    This is my menu.skin entry:
    B06,540,212,300,80,"LOAD;IGUIDANCE.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidance.exe;!IntellinavWCls!iGuidance",""
    and this is my RR.ini:
    gpspath=C:\Program Files\iNav\iGuidance\iGuidance.exe
    gpsname=Iguidance
    I had to do all this manually as config.exe only launches in memory on my 98 machine....I used an XP box to create the RR.ini and copied it over....
    The dude abides.
  6. #136
    Feb 2006
    Try:
    gpsname=iGuidance
    in RR.ini
    I have noticed that case does seem to matter. So iGuidance instead of Iguidance could do it. let me know.
  7. #137
    Apr 2006
    Quote Originally Posted by wishbone
    Try:
    gpsname=iGuidance
    in RR.ini
    no dice, i even copy/pasted it.... thanks anyways....
    The dude abides.
  8. #138
    Feb 2006
    try !iGuidance
    no idea what the "!" does but that seems to work as well sometimes =)
  9. #139
    Mar 2005
    Osk
    has anyone noticed any errors in the on screen keyboard when trying to use firefox or IE?
    it seems like it repeats the same key, or it doesnt move the cursor forward as you are typing and so you end up with the last letter you typed as the only letter in the address bar.
    is there something that I am doing wrong?
    this is a great skin by the way.
    thanks
  10. #140
    Jul 2005
    Wales, UK
    @ doctordl
    I've had this before but I don't think it's to do with the skin, it's more an RR thing. Have you got the latest version of RR? Try that to see if it cures the problem.
    @raymondrza
    This is a strange one. It does seem to be a window name problem as suggested by others. It might also have something to do with WIndows 98. Try this as your menu.skin entry for GPS:
    B06,540,212,300,80,"LOAD;IGUIDANCE.skin;iGuidance;C:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance",""
    ** NOTE: for some reason the forum is putting a SPACE between the semi-colon ( ; ) and C:\Program Files.... This should not be there - please delete it if copying n pasting) **
    This has no class name (Windows 98 may have a different class naming system). The class name is the part between the !s. This version just has the window name "iGuidance". There should be no difference in the way it embeds. Hope this helps!
    LLOYDY
  1. MMI eXtnd
    By proTONEd in forum FP Skins
    Last Post: 04-17-2008, 06:26 AM
  2. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  3. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  4. RR Holistic v2.2 Beta skin is ready for download
    By holistic in forum RR Skins
    Last Post: 02-05-2007, 10:21 AM
  5. iGmod Beta 2 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 05-12-2006, 03:52 PM
