Page 21 of 51 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 501
Thread: Simplistique Skin Release - download and screenshots
  1. #201
    Jun 2006
    Dude
    There's a skin in there for Map Monkey
    Open the menu.skin and change the GPS button to point to "GPS" instead of the Iguidance skin. As long as you've set up Map Monkey as your GPS app in RRConfig it should all be fine.
  2. #202
    Jun 2006
    Question Gps Button??
    SORRY i am really a newbeeee...
    Could anyone short explain to me how the load for internet explorer and mapmonkey should be?
    Mine is: B06,540,212,300,80,"LOAD;DESTINATOR_GPS.skin;DESTI NATOR_GPS;C:\DestinatorApps\Map Monkey\mapmonkey.exe",""
    MapMonk opens BUT not in the rr skin just as another program outside rr...
  3. #203
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by conan
    Make sure you have the correct window name in rrConfig. Should be MapMonkey (I think)
  4. #204
    Jun 2006
    I'll run you through it mate
    Open RRCOnfig, goto the GPS tab. You will then have options on what program you're using. Select Map Monkey and point RR to where the Map Monkey exe is located (C:\DestinatorApps\Map Monkey\Map Monkey.exe). You can also set the overspeed and volume mute options from here as well. There is also an FAQ on setting this up here: How do I setup my GPS Application ?.
    Ok, so once you've done that navigate to the Simplistique skin folder. Within this folder you will see a file called menu.skin, open this up in NotePad. Scroll down until you see this line:
    Code:
    B06,540,212,300,80,"LOAD;IGUIDANCE.skin;iGuidance;C:\Program Files\iNav\iGuidance Europe\iGuidance.exe;!IntellinavWCls!iGuidance",""
    Change this to:
    Code:
    B06,540,212,300,80,"GPS",""
    Now Map Monkey will load and embed perfectly.
    As for Internet Explorer, you have to set up your Web Browser settings in RRConfig (you'll see you have the option to choose IE or Firefox and you have to set the address. By default this is C:\Program Files\Internet Explorer\ieexplore.exe). I don't have access to my version of RR at the moment so I'm doing this all off the top of my head. It's pretty straight forward tho.
    Hope that helps.
  5. #205
    Variable Bitrate proph's Avatar
    Aug 2005
    Little Elm, Texas
    Can anyone do this Mopar log for the Dodge guys that can't stand the Ram head?
    http://www.albernichrysler.com/image...opar_small.gif
  6. #206
    Feb 2006
    I've just changed to map monkey in this skin, embeds fine, but in the upper right corner there is 4 green N/A signs, what are these for ?
    BMW 320 CI - 2000 mod.
    Xenarc/Gain 7" TSV with custom dash frame
    Epia M1000 shuttle pc- 80g hd, dvd, holux gps, linksys wireless
    Opus 120W, Trust BT v2 dongle, Wintv card
    Cadenze 500w rms monoblck,
    Cadenze 4ch 400w rms
    Alpine 12" Type R
  7. #207
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    probably infomation sent by the MapMonkey SDK with you haven't set up in MM yet.
    ie speed, heading, GPS co-ords etc.
  8. #208
    Jun 2006
    Exactly man
    It's GPS info ... From memory its:
    1. Location
    2. Suburb (town, etc.)
    3. ETA
    4. ETR
  9. #209
    Feb 2006
    Quote Originally Posted by B|ade
    Exactly man
    1. Location
    3. ETA
    4. ETR
    thx, but how do I set ut this settings to display correctly. I have N/A signs on location paramets in my MM skin also. Dosen't look very good with 6 N/A signs when using my GPS.
    Alpine 12" Type R
  10. #210
  1. MMI eXtnd
    By proTONEd in forum FP Skins
    Last Post: 04-17-2008, 06:26 AM
  2. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  3. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  4. RR Holistic v2.2 Beta skin is ready for download
    By holistic in forum RR Skins
    Last Post: 02-05-2007, 10:21 AM
  5. iGmod Beta 2 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 05-12-2006, 03:52 PM
