Page 3 of 51 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 501
Thread: Simplistique Skin Release - download and screenshots
  1. #21
    FLAC sama's Avatar
    Feb 2006
    London, UK
    Lloydy, this is going off topic a bit so I'll continue in an off-topic thread.
  2. #22
    Jul 2005
    Wales, UK
    The mute button should turn orange when pressed and then stay orange when the sound is muted. It should then go back normal when unmuted.
    If you''re talking about it not highlighting when the mouse is hovering over it then this is right. As I'm using a touchscreen only system so I didn't add any ON (hover highlights) to my skin as they were unessessary (you wouldn't see them as the button would be pressed before you it would appear).
    It's working for me but I will look into it. Which screen is it not working on (e.g. the menu screen or the audio player etc.)?
    The visu is embedded into the skin. Double tapping it should make it full screen however this depends on your WinAmp visualisation settings. For me, my carPC wouldn't run it in full screen mode and when using "fake full screen" mode (see Winamp settings) RoadRunner just re-embeds it.
    If you want to make it bigger yourself you can edit the audioplayer.skin file with the RR SkinEditor and increase the size of it. However, any bigger it won't look as nice (IMO) and you will lose the buttons that control the music.
    Hope this helps!
    LLOYDY
  3. #23
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I would like a version in 800x480 if possible
  4. #24
    Jan 2006
    I tried the mute button with a touch screen, and also with my mouse connected. on the menu screen and the music screen i can use the mute, but it doesn't turn orange like the rest of the buttons.
  5. #25
    Mar 2005
    I am experiencing the same problem myself with the mute button.
  6. #26
    Jul 2005
    Wales, UK
    Hrm..
    I have tried to look into the problem but my mute button works fine. I've even tried it on three different machines. Do you have similar problems with the other skins?
    LLOYDY
  7. #27
    Jan 2006
    Try reposting the file for download. and try it beforehand.
  8. #28
    Mar 2006
    Wiltshire, UK
    hey, love the skin, but im having issues wth the fonts? the clock and song playing is not the same font as you are using (verdana i think its using?) how can i go about fixing this?
    Thanks,
    Mike
    PS, mute is working fine here, and ighting up orange. BUT my volume bars are not lit up, and the volume changes but isnt shown as changing?!
  9. #29
    Mar 2006
    Wiltshire, UK
    its ok!...i used my common sense and decided the fonts obviously arent installed, so looked oin the skin directory, and saw some font files. Then thought there must be a font folder for wondows...and hey presto!
    Thanks!
  10. #30
    Jul 2005
    Wales, UK
    @ mike_b
    Is the volume slider working OK for you now aswell? I can't think what's causing that to happen. Although you do need the volume over 5% to see any bar light up. In RoadRunner the volume increases in 5% increments apart from the first 0% to 10% where it increases in 1% increments. The bars only light up in 5% increments (5% = half a bar) therefore you need at least five presses of the volume increase (5%) to see the first bar light up when starting at 0%!
    Hope this makes sense!
    LLOYDY
  1. MMI eXtnd
    By proTONEd in forum FP Skins
    Last Post: 04-17-2008, 06:26 AM
  2. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  3. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  4. RR Holistic v2.2 Beta skin is ready for download
    By holistic in forum RR Skins
    Last Post: 02-05-2007, 10:21 AM
  5. iGmod Beta 2 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 05-12-2006, 03:52 PM
