Fix it. Thanks
Can anyone tell me how to intergrate/embed WinAmp TV (Cinergy 600)
instead of the AVerTV one ??
And LLOYDY thanks for a cool skin.
Thansk in advance
Hey Enforcer
Thanks, but i ment embed Cinergy600 using WinAmpTV in the "Simplistique" skin ...
Don't i need to change something in the menu.skin and/or in the AVerTV.skin file ??
if it's just for the TV/video side then if the winampTV thing will work in the skin then setting up the winamp Tv module for whatever TV/Video/Camera you have should allow it to work kin the skin. (assuming you have the skin parts that allow aal2000 to use his averTV.
Unless I am misunderstanding something (always possible)
Here is a skin for Sirius support in Simplistique. It uses the same JPEG's as JohnWPB but the txt file includes the Sirius commands. Hope this can be use for somebody!![]()
You can either create a file called SIRIUS.skin with the below text and download JohnWPB's zip for XM support and rename the JPEG's as SIRIUS_ON.jpg, SIRIUS_OFF.jpg, and SIRIUS_DOWN.jpg
OR here is the whole zip file that includes everything you need...just download and copy into the Simplistique directory.
That's it for now. Thanks JohnWPB for the JPEG's.Code:MEDIACAR Skin MEDIACAR "radioplayer" Skin SIRIUS_OFF.jpg,SIRIUS_OFF.jpg,SIRIUS_ON.jpg,SIRIUS_DOWN.jpg /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B05,1,305,117,94,"SRNEWLIST", B08,126,303,134,93,"SRDELLIST", B09,-1,207,119,88,"SRADD1", B11,114,400,119,89,"NEXT", B12,122,210,130,84,"SRMINUS1", B14,2,405,111,81,"Prev", B15,737,318,60,54,"PGDOWN","Page down" B16,739,381,56,56,"DOWN","Down" B17,737,161,059,54,"UP","Up" B18,737,224,60,56,"PGUP","Page up" B21,1,500,110,98,"EXIT","Exit" B06,540,495,88,95,"VOL-","Volume-" B07,631,504,87,98,"VOL+","Volume+" B08,124,503,102,94,"MIXER","Mixer" /, I, x, y, w, h, Code;INDICATORCODES I06,715,502,91,95,"MASTERMUTE" /, Y, Back Slider file path Y01,"\volume_slider\volume_*.jpg" /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip S01,209,88,88,26,209,69,215,26,H,01,"",013,"SRTER","Ter Signal" S02,54,89,83,25,54,69,215,25,H,01,"",013,"SRSAT","Sat Signal" S03,303,520,215,46,303,520,True,46,H,01,"",013,"MASTER","Master" /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L01,562,89,232,34,255,255,0,18,"DotMatrix:B","SRSTATION","CENTER" L02,7,44,34,29,255,255,0,18,"Arial:B","TRACKNUMBER", /, B, x, y, w, h, Command;COMMANDCODES, Tooltip B,-10,113,350,83,"SRFAV", /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT L03,48,47,451,31,255,102,0,18,"Digital Readout Thick Upright:B","/ ||TAGARTIST||= - ||TAGTITLE||=","SCROLLLEFT" /, J, x, y, w, h J,653,5,78,77 /, I, x, y, w, h, Code;INDICATORCODES I06,740,395,55,34,"BOTTOMPL" I06,740,172,55,32,"TOPPL" /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name S01,377,164,344,270,255,255,255,57,57,57,192,192,192,255,102,0,255,255,255,TRUE,14,"Arial Narrow:B" END
Has anyone had any luck with powerdvd 6 in this skin? I've tried both powerdvd 6 and powerdvd 7, both with no success. If you are successfully running powerdvd 6, what are your settings? TIA!
Hey JohnWPB,
Are you up for building a CDRip Skin for Simplistique?
Setup:
Dynaudio 240GT
PPI PC4100, PPI PC2350
Zapco DSP6
ADS DAC
Testing new board (Albatron KI690-AM2)
"I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
