LLOYDY, is there a particular reason you went with an external dvd (powerDVD) for your skin, instead of skinning the "internal" one (MPC) that RR uses natively? I haven't tired this yet, but it might help with the green CONTROLS issues.
I've done some searching, but I can't find any particular advantages of using an external DVD player other than preference. Also just to be clear, the (SPACE) doesnt' work for me even if the DVD is already inserted before running the DVD function. Only (ENTER) would work. Maybe we're using different versions or your set to auto run or something? I've noticed in my version of PowerDVD (SPACE) activates/deactivates the pause function. Also I've seen guino has mentioned in previous threads that even the internal player will not work if you do not insert a dvd before you run the player. I haven't actually tested my (ENTER) "fix" with this kind of behavior yet, so I'm not sure if it will fix that particular issue.
Just thinking out loud. =)
LinkBack URL
About LinkBacks
