Page 2 of 23 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 229
Thread: Skin Release: BMW E36
  1. #11
    Jan 2004
    can I replace teh BMW logo int he middle like how can we do it for the regular BM skin?
  2. #12
    Apr 2005
    how do you switch between this view
    and tihs view
    Tried pressing bunch of buttons and don't seem to find it
  3. #13
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    I just added one of the flash logo clocks to this skin and positioned it over the BMW logo. I just copied the command from the BMV2 skin and then tweaked the numbers until the logo clock covered the BMW logo.
    I'm out of town right now and can't give you the exact skin command I used, but I can tonight if you want.
    Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  4. #14
    Newbie Master X's Avatar
    Jan 2006
    Quote Originally Posted by marazi
    you need to install the including font
    look for a folder "Fonts to be installed", there are 2 fonts:
    ARIALN.TTF
    Ericsson GA628.TTF
    put theese in your windows/fonts folder and youre done
    Thats the second thing I did after extracting the skin folder.
    EDIT: eh, the little bastard zip program kept them in the folder eventhough i set it not too. Works now.
  5. #15
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by Zogg
    Robby, just noticed that on the weather screen the button to go to the 5-day view says '1' instead of '5'.
    In which sense it “says”?
    Also, I miss the Power button on the main screen. I had brought over the exit menu from the BMV2 skin that gives you the exit, power off, reboot, etc. options. Any chance of bringing back the Power (or ESC) button on the main menu?
    I've removed the power button from the main menu in order to prevent an accidental system shut down. You can reach those options by the "config" button in the main menu.
  6. #16
    Aug 2005
    Italy
    Quote Originally Posted by corsab
    hallo
    which evrsion of powerdvd u use?
    i use powerdvd xp
    but if i set rr.ini correctly and update exetb.ini with your command....the rr crash and i don't use dvd player!!!!
    puoi mi spieghi come fai ad usare il cdmonitor!!!!
    I use the 4.0 version, but I've noticed that there is a bug in the last RR release with the external DVD player.
    I think Guino will solve this in the next release.
  7. #17
    Aug 2005
    Italy
    Quote Originally Posted by eblend
    and tihs view
    tap the return button (that with an arrow) in the bottom right
  8. #18
    Apr 2005
    Plano, TX
    My bad, it's the pre-release version that has the mistake on the weather skin.
    Regards,
    Z
  9. #19
    Nov 2005
    very nice skin!
    it's the one i'm using :-)
    does the camara button works ?
  10. #20
    Aug 2005
    Italy
    Quote Originally Posted by ThE_KiLLeR
    very nice skin!
    The camera button works with Capture! software (download it here).
    Edit the "ExecTBL.ini" file in the skin directory (not the one in rr directory) and change the line
    "CAMERA","LOAD;CAPTURE.skin;;C:\Programs file\Capture!\Capture!.exe;Capture!"
    with the path where you have installed "Capture!".
    Don't change the default key shortcut in Capture! configuration.
  1. Kuo Skin Release
    By kuo in forum RR Skins
    Last Post: 12-04-2008, 03:46 PM
  2. (AUS) BMW E36 Extensive Customisation
    By CAA in forum Show off your project
    Last Post: 06-13-2008, 04:44 PM
  3. mac style skin release...
    By btbe in forum RR Skins
    Last Post: 08-14-2007, 10:07 AM
  4. 1992 BMW 318IS (E36) Carputer
    By Digital318is in forum Show off your project
    Last Post: 03-09-2007, 08:42 PM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
